Eibach Sportline Lowering Springs
Hi, I was wondering if I need to buy anything other than the lowering springs. I don't want to end up buying them and not have enough parts to complete the install and end up paying more than what I hoped for. This is for a 2011 tC.
Not super familiar with the tC2, but Sportline springs might be a bit much for OEM shocks. They will likely wear out faster. I'd recommend that you go with a sport oriented shock like Tokico or similar.
Besides that, you shouldn't need much. Rent a spring compressor from the auto parts store for free (once returned). |
I know it's a late reply but I had them for a bit but of upgraded to coils after a year. I really enjoyed the ride height. Other than the spring you don't need anything else.
Old reply but FWIW I had the Sportlines for a few months and they made a ton of noise up front when turning and going over bumps. It was extremely annoying. Ended up getting them RMA'd thru Eibach and then replaced them with the Tein S-Techs. They ride 100% smoother, handle better and the car sits a lot more evenly. 100% recommend the S-Techs over the Sportlines.
Also to answer your original question, unless you want to run ~3 degrees of negative camber in the rear you will need to install adjustable camber arms back there as there is no factory camber adjustment. They're ~$200 for the SPC's I have. Megan also makes a kit.
Originally Posted by bbsciontc
(Post 4284949)
