kSport Kontrol Pro Coilovers
So, I've had these coils since June and I've been pretty happy with them up until it got cold out. I recently raised my car, and did it properly. The rear struts seem to freeze up and are extremely loud over small bumps. I thought I did it wrong, and I checked them again, and they are correct. Today it's almost 70 out (Welcome to Rochester, NY) and no noise. The rear struts seem to be compressing and expanding just fine.
I heard that Ksport coils tend to seize up during the cold months, is this true? Anything below 60ish seem to be an issue for the coils. I spent almost a grand on these coils, after other reviews for Ksport were generally good. They were a PIA to install, especially the rear the first time. |
i havent had any problems with them bro...its gotten to 45 down here and i havent had a problem with that...did you put the struts in right? you have pics??
Originally Posted by k0ntr0lledka0s
(Post 4073669)
I understand you installed them correctly, but did you adjust them correctly. Not only do the springs have to be adjusted, but the rear struts have to be adjusted depending on the ride height you settle on.
White lithium grease bud
o my bad yea it doesnt get that cold down here i wouldnt be able to answer that sry, but noskatehate22 is right you have to align them right according to your ride height
Originally Posted by noskatehate22
(Post 4073771)
I'll lube them up and see how it is. How does adjusting them going to be affected by the cold? Yesterday, it was really warm. It was 69F out. No issues. |
havent had any either and ours has hit low 30's a few times
