Progress sway bar clunking noise
Hello,
Not even a week later from the install i started to hear a clunking noise from the rear side. The noise only happens when driving slow under 30 mph over a small bumps on the road. I did make sure all the bolts were tighten close to specs. I did notice that the passenger side end link that is bolted to the frame(factory mount) of the car is making the clunking noise almost like if the end link connected to the frame (not the sway bar) is lose even though the bolts are tight. Iv had this noise for some time, i figured it would go away or settle but it still continues. wondering if anyone else has had this problem or if there is a solution or if it can just be a bad end link?
Any thoughts or suggestions are welcome.
Thank you
Thank you
this happened to me before when I upgraded my bars with my tc1
the bars are so thick and the endlinks couldn't handle it so it broke. the remaining bottom piece of the endlinks was just hanging loose banging on the chasis.
you can check that out.
solution is usually with an upgraded thicker bar you should get new endlinks as well.
RY_TC07
07-18-2017 05:18 PM
