Scion tC 2G Suspension & Handling Coilovers, Shocks, Airbags, Swaybars...
Rear Camber fix? Has anyone tried these yet?
Old 09-26-2012, 02:26 PM
BlackDaHlia's Avatar
Default Rear Camber fix? Has anyone tried these yet?
Whats up everyone, I am new to the site but have had my tC for a year now. Anyway I have yet to lower my tC because of the rear camber problems that everyone has been having and Id rather not spend all my money on tires. I was curious to know if anyone has used this product yet and if they could give a review.
http://www.fastscions.com/spc-perfor...3-75600-1.aspx
BlackDaHlia is offline
Old 09-26-2012, 11:24 PM
ANMLxB's Avatar
I'm guessing it would help a lil bit but I'm not sure. I'd rather get a slimmer tire size to give it a lil stretch so it won't rub.
I'm running 19x9.5 in the rear and it's always rubbing even after I rolled the quarter panels.
ANMLxB is offline
Old 09-26-2012, 11:55 PM
keeev's Avatar
Cool find, didn't know these were available. I wonder if these are safe to use and doesn't affect our ABS.
keeev is offline
Old 09-27-2012, 01:29 AM
Well anyone with a drop care to give these a try and let us know if it helps?
Old 10-01-2012, 06:59 PM
DaYUUM/Scion Evolution
KidJustin's Avatar
i'm still doing research, but i'll probably try it out
KidJustin is offline
Old 10-02-2012, 01:05 AM
2tCornot2tC's Avatar
Already discussed here... https://www.scionlife.com/forums/showthread.php?t=205597&page=8
Y U no search?
2tCornot2tC is offline
Old 10-03-2012, 12:29 AM
KidJustin's Avatar
^^because i dont want to use "info" from forums.
Old 10-05-2012, 04:57 AM
meganfoxed's Avatar
could anyone explain to me how/if this works?
meganfoxed is offline
Old 10-05-2012, 05:16 AM
Have you ever tried to press in a bearing crooked? Well, it doesn’t work…most of the time it destroys the housing (the upright in this case) because the housing is a softer material than the bearing. This kit purposely and intentionally ***** the wheel bearing in your upright! This plastic piece is inserted between the 4 flange bolts holding your rear wheel bearing to the upright. It is quite a cleaver design…they put two plastic discs (shims) together that are fabricated at a 0.75-dgree angle. When you rotate them, you can set an angle anywhere between 0.0-degrees and 1.5-degrees…at the cost of offsetting your wheel bearings (and therefore your wheel) by the thickness of these two angle shims. Not a bad idea to **** a spindle, but not for a bearing! I used these on my Honda Fit and they worked OK because it cocked the whole spindle. I had to buy longer high grade bolts because the OEM ones were not long enough with these shims installed (and no alignment shop will install longer bolts for you)…bolts are NOT included with these shims. If somebody here does it, my guess is that you will be burning up rear wheel bearings. Somebody here do it…and report back to us how long it took you to burn up your rear wheel bearings. It will be dependent on the amount of misalignment you had to dial in though. But we could set up a table here for burn time in relation to set angle.
Old 10-05-2012, 07:48 PM
meganfoxed's Avatar
thanks for the explanation. i think i'll pass..
Old 10-07-2012, 06:00 PM
shockerz's Avatar
Since the majority of the problem is on the passenger side, how much longer would the arm need to be to put it back in spec?
i'm not wanting an adjustable set up, but i would like for it to be in spec, i wonder how much it would cost to make a longer one to correct it?
I sitting on S-tech springs and the camber is at 2.5 right now.
shockerz is offline
Monkey343
Scion xD Suspension & Handling
11-10-2016 02:07 PM
scionhawaii
13
06-19-2015 03:59 PM
jcraff3
02-20-2015 11:41 PM
TheTripleC
01-04-2015 06:46 PM
kleecker
01-02-2015 08:09 PM
Quick Reply: Rear Camber fix? Has anyone tried these yet?
