tC2 Raceland Coilover Review
Car looks sick man xD
I just installed mine a few days ago and the front ones are really noisy. It's like a loose rattling sound. I double checked to see if everything was nice and tight and everything was. Are they supposed to be noisy? This is my first time ever having aftermarket coilovers so I wouldn't know. Help ?
So upon doing some research (parts searching) xtec auto usa now makes/ has Adjustable Rear upper control arms for our cars and they are reasonably cheap when compared to 2tcornot2tc (sp), not dissin what you have done 2tcornot2tc but are more on reasonable price point.
a couple companies, like SuperTek and a couple more are working on a legit set
Just got my coilover today from raceland I was looking over the instructions they provided it said something about cutting the rubber piece that goes with the top hat said u had to trim off a piece and it was highlighted and it stated that it needed to b done if u wanted the install to b correct. Just wondering if u ran into this and if u trimmed ur rubber piece sorry idk what ita technically called lol
Sent from " NOT AN iPHONE "
First sheet was a warning
Next sheet at the top says " scion tc2 rear installation"
#1 the oem rubber spring insulator pad will need to be trimmed in order to mount properly. Trim the highlighted area.
#2 the oem dust cover will nees to be trimmed in order for the upper shock mount to install properly Trim the cover where shown.
You said you had Tein S-Techs prior. How do the Racelands coils compare to the S-Techs in ride quality and performance. I searched and all I found is the quick mention of performance in your inititial post.
First sheet was a warning Attachment 13599
Attachment 13600
Attachment 13600
Dang I haven't replied here in a while.
Mine didn't come with instructions either. I'm not sure if they forgot to put them in mine or if they just started putting instructions in there or what.
The racelands blow the s-tech's away as far as ride quality and performance go.
The quality was good while I had them on, but I only used them for 3 weeks until I decided to part out my car. These racelands as well as TONS of other stuff is for sale in my part out thread: https://www.scionlife.com/forums/sho...d.php?t=220580
Obviously when u lower a car u should get an alignment. I have not has anyone got an alignment yet for the raceland sleeves. Im wondering how to get the rear in spec so my tires dont continue to wear horribly.from what ive seen read heard there is no camber adjustment
