Are there any other brake options?
If this question has been address in a different thread already please point me in that direction, I couldn't find anything. Is there any other brake upgrade that is bolt on other than the TRD kit?
you may be able to upgrade the pad material and pad quality and that should make a difference. will not be too expensive either.
there are a number of rotors available...
drilled, slotted, drilled and slotted, etc as well as many types of pads they are no where near the "upgrade" level as a TRD BBK, but they are there and easily found when searching |
I dont want to start any arguments here but I think the big brake upgrade is a waste of money if you have a daily driver. Unless youre pushing serious power then you should consider the TRD kit. I am switching to a better quality pad & rotor once my OEMs wear out.
Originally Posted by KILLER
(Post 4138793)
Get this... http://www.dezod.com/pd-centric-posi...ke-pads-tc.cfm They have the rears as well... |
