Braking Distance length?
Old Jul 19, 2012 | 04:02 AM
Xander2011's Avatar
Cool Braking Distance length?
Hey guys, I was just wondering if anyone knows of the 60-0 braking distance of the 2nd gen tC? I've seen different reviews with different numbers and was wondering which one is right? I've read on one that its 124ft and another saying its 139ft. I'm asking because I'm thinking of getting the TRD brake kit but if there isn't much difference in braking distance, I might as well save the money for some TRD rims.
Old Jul 24, 2012 | 04:38 AM
2tCornot2tC's Avatar
Old Jul 25, 2012 | 06:07 AM
Scion202's Avatar
come on, it would have taken you less time to type up a 3 digit number than get this pic posted
Old Aug 31, 2012 | 12:00 AM
russiankid's Avatar
No point in spending money on a TRD BBK unless you're planning to track the car, which in that case a good set of pads and rotors will be cheaper and you shouldn't have any issues.
Old Aug 31, 2012 | 03:14 AM
Hey Russian geniASS, you’ve just proven to the world that you have no idea of how brakes work, that you are not a brake engineer and probably that you don’t even have a technical background at all. One of the first things that people do to their cars here is put on wider wheels and tires (with grippier tires) which will overwhelm the brakes in no time if driven a little spiritedly or on a mountain road. Search and you will learn...already discussed here.
Old Aug 31, 2012 | 03:24 AM
russiankid's Avatar
You're right, I am not a brake engineer. Does that even exist? Pretty sure that just breaks down to basic mechanical engineering and heat transfer.
I guess after driving my tC on mountain roads, autox, etc, and previous vehicles that weight a lot more than the tC I have yet to cook factory brakes with the exception of correct pads, I have no experience.
I now see why I was warned away from this forum, everyone is an engineer. If it were that easy I wouldn't go to school for it.
Old Aug 31, 2012 | 03:31 AM
I’m sure the engineers at Brembo, StopTech, etc. would be offended by your statement.
Old Aug 31, 2012 | 03:49 AM
Brakes appear deceivingly simple at first glance, but delve into the actual design and a significantly more complex problem emerges. Mass times acceleration (negative numbers in this case) will equate to about 1000-HP to 1200-HP in braking power! Not chicken $h!t.
Old Aug 31, 2012 | 12:38 PM
russiankid's Avatar
Mass x acceleration does not include rotational mass that is given by the weight of the wheels and other rotating components in the drivetrain. Increasing clamping force on a slightly larger surface area will help but not yield significant gains. This is why when a BBK is installed, the rotor circumference is increased significantly.
Also don't forget that suspension and tires play a large roll in braking distance.
Old Aug 31, 2012 | 01:01 PM
Yes it does! I didn’t say partial mass… Finish your engineering degree, then we’ll talk. You’re talking about un-sprung mass (include rotational here) in the wrong place.
And you are wrong again! Where in the friction force equation does area come in? The equation is “mu” (friction coefficient) times “n” (normal force) [for brakes we will take the surface area of the pistons times the hydraulic pressure] equals “f”. No area…
Wrong again! If you actually run the numbers, an OEM replacement BBK does NOT increase the braking torque at all. That is why you can install them with the stock rear brakes and not upset the braking balance of your car.
That’s what I’ve said here…
One of the first things that people do to their cars here is put on wider wheels and tires (with grippier tires) which will overwhelm the brakes in no time...
Old Aug 31, 2012 | 01:07 PM
Roller_Toaster's Avatar
Welcome to scionlife russiankid....
Old Aug 31, 2012 | 01:09 PM
ProjectTC2's Avatar
^^ You've been initiated now!
Old Aug 31, 2012 | 01:25 PM
I’ve scratch built several race cars in my time, one of them being an F-1 car. I know an awful lot about car’s chassis and suspensions. Not just the fabrication of, but design of too. If you go telling us wrong technical information, I’m ruthless. I’ll be rude, crude and uncalled for…I take it personally because a lot of people think that because they have built something, that that qualifies them to be an engineer. And I find that insulting! Next time ask us, we’ll probably tell you.
Old Aug 31, 2012 | 02:01 PM
russiankid's Avatar
I know and understand what you are saying but I think your missing the point I am making. I am not the smartest nor the dumbest person in this subject. I am well aware how brakes function, how a larger circumference equated with more eventually distributed hydraulic clamping force reacts better than a force acting in a single location on a smaller circumference disk. If you have built track cars before you should know that increasing hydraulic pressure is not only the caliper setup but the master cylinder.
I am always open to learn but don't insult me. What most people on this forum have planned for their cars, stock brakes will be fine. Maybe I keep getting lucky with good pads, but I don't have any problems stopping.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
gqdabien
Oct 8, 2015 05:36 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
Subaru86
Scion FR-S Aero & Exterior
Sep 14, 2015 12:39 PM
