Steelies and snow tires
With winter around the corner I'm looking for steelies and snow tires for my 2012 tC. I can get 17" steelies but my first question is if ill be able to fit a 16" steelie on my tC, if I can tires for me would be a lot cheaper
yes a 16 fits given the right offset. As long as you stay at or below offset (+37 I believe.)
I got a set of 16" x 6.5" steelies from Tire Rack with a set of winter tires (215/60 R16) mounted and balanced. I don't know the offset of the wheels, but the hub ring is an exact fit, so no hub centric rings to worry about.
Lastly, I noticed that the front brake calipers just barely clear so I don't know if 16" wheels would clear the TRD big brake kit. Anyone out there know the answer to this? I think the spare tire is 16" so this would be an easy test for someone with the TRD kit.
So your telling me you get a flat in the front with the bbk the spare is useless or do they expect you to move a rear wheel foward and put the spare in the rear?
Remember that the bbk was designed after the car was produced. Just get a 17" doughnut spare, run flats, or rotate tires when changing a flat up front. It's not the end of the world, besides how often does someone get a flat... Just my two cents
Got a flat as a result of a carpenter screw that I somehow picked up this happened three days of me owning it. Lucky I have a car compressor so I filled it up and got it fixed at Toyota for $64 Seems to me that Toyota is really dropping the ball all over the place. In a world that an old lady can sue McDonald's for her hot coffee being hot and win that Toyota would really focus on things like this. I can see some little old lady in her scion tC with bbk that she purchased because she wanted the additional braking power catching a flat on a desolate highway and ultimately being raped and mugged or worse just because the spare didn't fit. I hope you can live with yourself Toyota.
You didn't stop to help? You monster! On a serious note we live in a sue happy society although this isn't a frequent issue, given Toyota track record I'm surprised that they're still opening themselves up for a lawsuit. Do they even disclose that the spare will not fit the front of a tC with a bbk?
"The TRD high performance brake kit delivers confidence-inspiring performance, enhanced pedal feel and improved braking torque distribution between the front and rear axles. A patented, directional AeroRotor internal cooling vane design induces greater airflow to cool the rotors, providing consistent performance in repeated or heavy duty braking.
Specs:
Opposed 4 piston fixed calipers
323mm x 32mm cross-drilled rotors
Braided stainless steel brake lines
Kevlar/Ceramic compound performance brake pads.
Minimum clearance requires an 18” wheel."
That's what it says about the BBK on the Scion.ca website, but it doesn't explicitly state that the spare tire is smaller than that, so if you can put and one together then you would know. That, however, doesn't seem to be the case in most situations involving suing.
To get back to the original topic, I currently have 16" steelies w/winter tires, over the stock breaks and they fit not much clearance but no issues.
Specs:
well i dont have the big brake kit, so 16" will fit fine then? reason i was concerened is because i dont wanna shell out hundreds and hundreds on winter wheels/tires, snows for 17s here are costly, but 16s can be nearly 30-40% cheaper compared to 17s
Yes 16's will work for you
16" rim WILL NOT fit over TRD BBK... my 16" rims barely fit over the stock caliper. if i were to hit a bad enough pot hole to bend my rim i would probably have to replace my STOCK caliper because of fitment being so tight. TRD might be made by toyota, but its technically aftermarket
evolving_machine
Scion xB 2nd-Gen Wheel & Tire
12
01-18-2016 08:41 PM
Yakimaniac
Scion xD Wheel & Tire
11-22-2014 04:20 PM
