Will This Wheel fit? (Guide to Offsets and more)..
Old Apr 9, 2013 | 01:04 PM
  #281
12BlacktC2's Avatar
Originally Posted by SullenSenium
12BlackTC2 I will go with Enkei GTC01 in 18x9.5 +38mm Hub Bore 73mm. What spacers will I need? And also can I use the aluminum hub rings from 1010tires.com and what size? Thanks!
You'll need an inner diameter of 60.1 (the stock hub bore) and an outer diameter of 73 (the hub bore of the rim). I went back and forth on whether to use plastic or aluminum. Ultimately I went with the plastic... I felt that with that many moving parts (even torqued to spec) hub/ring/spacer/rim the plastic would fit better if there were any microscopic imperfections... I'm sure whichever you went with would be fine. I bought mine here:
http://www.ebay.com/itm/330869624815
Old Apr 9, 2013 | 03:08 PM
  #282
oblivionlord's Avatar
Where is it listed that the bore size is 73.1 because Five Axis doesn't list that spec?
Old Apr 10, 2013 | 06:44 AM
  #283
SullenSenium's Avatar
Thanks! And what spacers will I need? Also do you think I'll need to roll the fenders?
Old Apr 10, 2013 | 01:09 PM
  #284
12BlacktC2's Avatar
I didn't buy mine directly from Five Axis. I actually got a deal on the set of 4 from a guy on ebay. They weren't a direct fit to the tC2; thats why I had to go with the hub ring/spacer set up. I believe, and I may be wrong but, if you buy it directly from Five Axis they would come with the correct hub bore negating the need for hub rings. I knew that as long as I could correctly figure the backspacing and the bolt pattern was correct I could make them fit...
Old Apr 10, 2013 | 01:19 PM
  #285
12BlacktC2's Avatar
You might want to double check your sizing... Enkei lists on their website the 18x9.5 et38 only comes in a hub bore of 75. I was looking just to see what the rims looked like. The size chart for the GTC01 is here: http://www.enkei.com/size_chart/GTC01.pdf
As for spacers; you'd need a outer diameter of 75mm based on the Enkei size chart with a inner diameter of 60.1. You should be able to find them on eBay or 1010 should have them also.
As for fender rolling; I haven't rolled my fenders and I'm running a 15mm spacer in the rear on a 45mm offset (in essence bringing the offset down to 30mm) so you should be good there. If anything you could add a 5mm spacer if you wanted to fill in the wheel gap. For the front it should bolt right up but you might have to roll the fenders. With the 45mm offset on mine with no spacer I'm not rubbing, and have about 8-10mm of gap between the tire and the fender. That's one that you'll have to try and drive it.
Are you dropped? If you're riding on stock springs you should be fine. I'm lowered on D2's so it may be slightly different. Also since you're running 18" rims and I'm on 19's there may be a slight difference in overall diameter...
Hope this helps. Good luck and we better see some pics!
Old Apr 10, 2013 | 08:57 PM
  #286
Hehehe they are not that special, as a matter of fact they look like the stock rims a lil' bit, the reason I choosed them was because of performance and features, reason why I didn't went with 19's, trying to save on weight. Not drop yet but by the time I get my wheels I'll be running on Tein Super Street Coilovers maybe a 1.5" or 2" drop. I was confused, I thought a needed spacers + hub rings, that's why I asked twice about the size needed for both, sorry for that. And the 73mm measurement I got it from Amazon so I'll go with Enkei's official size of 75mm thanks for clearing that out!
Old Apr 11, 2013 | 12:54 PM
  #287
12BlacktC2's Avatar
Absolutely! You'll only need the hub rings if the rims don't match up to the stock bore. As for spacers; they have been pretty heavily debated on some other forums here. I use them for the look...
Old Apr 13, 2013 | 12:10 PM
  #288
12BlackTC2 how is your turning radius with the 9.5" wide front wheel with and without the 5mm spacer? Are you able to lock out completely or does the wheel hit something?
Lastly how would the ride quality be if you were to just be at a finger gap of spacing on your 245/35?
Old Apr 13, 2013 | 02:00 PM
  #289
12BlacktC2's Avatar
I haven't put on the the 5mm spacers yet... They should arrive sometime this week. Without the spacers I can go from full lock to full lock with no rubbing/hitting anything. The 15mm spacers in the rear make a perfect fit on the 19x9.5 et45 rims.
The tires provide awesome grip though I haven't had a lot of time since I've got less than 200 miles since I added the drop/rims/tires... Its tough to compare ride quality of the tires since the suspension is so much firmer with the coilovers. This isn't my daily driver... Once the weather breaks in upstate NY I'll spend some more time fine tuning the suspension. I've strictly added the spacers for aesthetic appeal...
Old May 1, 2013 | 12:45 AM
  #290
VuDism's Avatar
I'm about to get a set of used rota g-force 18x9 30mm offset. Opinion if these will fit OK without sticking out?
Sent from my Nexus 4 using Tapatalk 2
Old May 1, 2013 | 11:47 AM
  #291
k0ntr0lledka0s's Avatar
yea you should be good with that wheel...you don't even have to roll the fenders
Old May 1, 2013 | 12:48 PM
  #292
I just recently bought five axis wheels the same exact size as yours. After fitting them on I've realized that you don't need spacers at all. They are already flushed to the fender providing you have camber adjustments at the front and rear. My meganracing coilovers have from camber adjustments, but not the rear. I am getting xtec for the rear. Without the camber kit, the wheels will seem to have a gab beneath the fender which a spacer would fix, however you'd be wearing out your tire that way.
I will take pics of how it looks when I have the rear camber installed.
Old May 2, 2013 | 10:54 PM
  #293
carbinefreak's Avatar
Just an update, on the stock suspension with my 18x9.5 35mm offset enkei PF01's are perfectly flush no rub lock to lock. i'll update after the tien super street coils are on.
Old May 4, 2013 | 02:03 AM
  #294
juancho's Avatar
I just set up my wheels on Meagan's in the front their completely flush but I, also running a 25 offset... Rolled them jst in case... But no rub or nothing my rears however well that's a different ball game 10.5 et 22 is a pain to get flush with out fixing the camber issue
Old May 4, 2013 | 12:10 PM
  #295
If your front wheels are 19"e22 and not 19.5"e22 at neutral camber then that could be the reason why yours are naturally flush at the front. With my 9.5"e45 at neutral camber, It's virtually flush as it is. However I can still add a 5mm spacer without it protruding. That 5mm to me is extremely minor.
Your rear however being 10.5" e22 at neutral camber will easily protrude beyond the fender. You may as well just keep it at negative camber.
Then again I doubt you are worried much about tire wear to begin with since you went with the staggered look. To each his own I guess.
Old May 5, 2013 | 02:38 PM
  #296
12BlacktC2's Avatar
Very Cool! What tires did you decide to go with?
A quick update... I added the 5mm spacers and have encountered some minor rubbing in the front. I've put about 500 miles on the car since I installed the drop/rims&tires so it seems to be settling in pretty good. I've made arrangements with a guy locally to roll the fenders. The ride quality is stiff as expected; but I'm extremely happy with the performance of the Hankook Ventus V12 Evo's
Old May 7, 2013 | 01:52 AM
  #297
BeAlLsTaR13's Avatar
so after a lot of thinking on size/offset im gonna do xxr 530s 18x8.75+33 front, and 18x8.75+20 rear, im dropped on eibach sportlines (1.5f 1.7r iirc) will be using stock tires... i shouldnt have an issue with any rubbing in the front or rear correct? i won't be adding spacers or anything
Old May 7, 2013 | 11:47 AM
  #298
yea you should be good bro, you wont have problems with that setup
Old May 10, 2013 | 06:18 PM
  #299
VuDism's Avatar
decided to bite the bullet and ordered fresh 18x9 +35 ENKEI RPF1s from Paul @ Dezod Motorsports. STOCK = 26.5 LBS vs RPF1 18.4 LBS. Needless to say i am butt-siced about losing 8+ LBS of weight on each corner!
Old May 10, 2013 | 06:48 PM
  #300
scionchicop's Avatar
^great choice. You'll notice the difference in the weight reduction immediately.
