Will This Wheel fit? (Guide to Offsets and more)..
1. 18x9.5 +30et
2. 245/45/18
3. ksports. tried 2" drop front and back. rubbing.
NOW-front drop-1" rear drop- .5" still rubbing...
WHY?? need help!!!
4. willing to roll fenders-looking(SoCal/OC area).
2. 245/45/18
Based on the first page you shouldn't be rubbing.
When is it that you notice the rubbing
Sent from JARVIS
front rubs on straight run. mostly on left side. maybe when i adjusted it, i did something wrong. cause literally 90% it's just the left side.
rear rubs when entering a commercial place or into my driveway, when it's going up.
i wish i have GoPro so that i could record.
thats really strange, i don't really know what could be causing that, to what i know for fitment you should be clearing without any issues. id re adjust everything to see if it was a little off.
ok so front is cleared. but i think i put too much height. problem left is my passenger side rear tire. i adjusted it again last night, but like 2mm. it got better, yet i still rub on freeways on those sudden dips/humps. my car looks like a stock now. ahahaha
maybe i need to roll my fenders.
or get thinner tires and stretch them.
mine are 19x8.5 +30 offset withe 235/35/18 and my fronts are flush. my wheels are an 1" bigger/taller but urs are 1" wider that's why your having issues
So I have a 2014 tC with Eibach Sportline springs and I want to purchase a set of wheels that I can get a deal with but would like to know if it will work in my application.
I can get these rims for 200 bucks for all four but I will only purchase if they will work on my tC.
Currently have stock/factory rims (18")
Thinking of purchasing
ASA GT06 (Black w/mach Lip)
19x9.5 Rears
19x8.5 Front
bolt 5 ET +45
pcd 114.3 hub 79.5
With my drop can I use this?
___
19x9.5 Rears
19x8.5 Front
bolt 5 ET +45
pcd 114.3 hub 79.5
___
anyways, my car has a look of stock height at the rear now. yet my tire, just on rear driver side, still touches my fender every time i turn right especially entering a commercial place, and on dips/humps on freeways.
1. Rim size and offset: 18x8.75 +20mm
2. Tire size: Dont know? Can you recommend a size for good fitment?
3. Suspension Setup(Spring/Coils) and drop: Tien Stech Springs
4. Willing/Rolled Fenders? Not rolled but will if needed
1. FIVE AD R5 19x9.5 all around (only ones they have in stock left, wanted 19x8.5)
2. 235/40/19
3. Eibach Sport line 1.5" ish drop
4. If necessary, if it is possible without rolling would be the best.
Questions:
- will it rub?
- how much would they be sticking out? (not trying to look like a ricer)
2. 235/40/19
Questions:
- will it rub?
2. 235/40/19
Questions:
- will it rub?
2. 235/40/19
Questions:
- will it rub?
@+35 you will rub in the front but should be fine the rear...a minor fender roll should do the trick and probably go with 235/35 instead of 235/40
@+25 you will definitely rub both front and rear and it will poke out a lot...about 3mm in the rear and about 1.5 cm in the front
with that said...i'm selling a well taken care of set five:ad S7 19x8.5+30 perfect flush fitment for the tC2 (check out the link in my sig to take a look)
the one they are offering are +22 offset so i guess thats a no go? they are currently selling it for 500 for 4 pc (NEW) unless i can get a better discount than that ;F
EDIT: after looking at your rims they do look really nice but 1100 is a bit too much for me :/
