Will This Wheel fit? (Guide to Offsets and more)..
Old Jan 27, 2014 | 10:51 PM
  #441
zerosky's Avatar
18x9.5 +38 offset
Lowered on Eibach sport line
1.3 front 1.7 rear.
I figure I'm going to have to roll my fenders but wondering if the offset will will have my flush or odd looking
Sent from JARVIS
18x9.5 +38 offset
1.3 front 1.7 rear.
Or 25 offset
Sent from JARVIS
Forgot to say that the 38 would be front and 25 would be rear
Sent from JARVIS
I just posted this in the wrong section -.- any chance to have it moved?
Sent from JARVIS
Old Jan 28, 2014 | 08:06 AM
  #442
MistaB's Avatar
Originally Posted by MistaB
1. Rim size and offset: 18x8.75 +20mm
2. Tire size: 235/40/18
3. Suspension Setup(Spring/Coils) and drop: Tien Stech Springs
4. Willing/Rolled Fenders? Not rolled but will if needed
Anyone?
Old Jan 28, 2014 | 08:32 AM
  #443
zerosky's Avatar
Not sure since I'm still new to the tC set up but 205-225 I'd say would be a start but id say wait for the experienced members to log on and say what they recommend.
Sent from JARVIS
But you will have to roll fenders. The S-Tech do drop a lot and being at a +20 offset you are gonna poke out a lot.
Sent from JARVIS
___
Old Jan 28, 2014 | 02:45 PM
  #444
KidJustin's Avatar
DaYUUM/Scion Evolution
zerosky offsets should be fine, just minor fender rolling in the front and rear. flush
MistaB front will stick out a lot- u will either need to add camber, stretch the tires a lot, or pull the fenders a lot. you will most likely have rubbing issue turning if not. 235/40 is too thick. rear is fine
Old Jan 28, 2014 | 06:47 PM
  #445
MistaB's Avatar
Now for the fronts how would +33 offset be?
Could you also recommend tire size for them?
Old Jan 29, 2014 | 05:19 AM
  #446
zerosky's Avatar
Default Will This Wheel fit? (Guide to offsets and more)
33 you'll be good since it's closer to stock offset. That's why I'm going with 38 since that is stock but going with a rim that's 1.5" wider. The rear there is more room to work with.
You'll still have to roll the front fenders but no where near the work you'd have to do as with a 20 offset
Sent from JARVIS
Old Feb 4, 2014 | 02:29 AM
  #447
Prosk8er735's Avatar
I'm trying to see if my friends stock 2010 lancer wheels will fit on my tc for snows.
Stock ride height
Pitch Center Diameter- 5x114.3
Wheel size- 18x7
Offset- 46mm
Hub- 67mm
Tire size- 215/45-18
Can I make this fit ?
Old Feb 4, 2014 | 03:04 PM
  #448
KidJustin's Avatar
wow the lancer has such a small wheel.
think of it this way, as posted on the first post, the stock tC2 wheel is 18x7.5+39
the hub is a different size though, so you will need at least hub rings
Old Feb 9, 2014 | 11:31 PM
  #449
MusTC's Avatar
Default Wheel Fitment Question
I'm looking to get a set of Rota Grids (18x9.5, et 35), wrapped in 225/45, but have no clue as to whether I will have proper fitment, or whether I'll have to worry about excessive rubbing. Currently I'm dropped on Megan coilovers with a 3 inch drop in the rear and just under 3 inches in the front; Max camber adjustment in the front is 2.5 inches. Ideally, I don't want to have to roll my fenders. Any thoughts, suggestions, picture examples?
Old Feb 10, 2014 | 11:52 AM
  #450
k0ntr0lledka0s's Avatar
you will actually need to roll your front fenders with those specs, unless you find ones with a smaller width or you raise your car a bit. Your rear should be fine though
Old Feb 10, 2014 | 03:04 PM
  #451
fatty_gen2's Avatar
I always thought the offset impacts the fenders not the width and the width only affect the inner fender (offset permitting).
Can you confirm?
Old Feb 10, 2014 | 03:13 PM
  #452
KidJustin's Avatar
Can you confirm?
width and offset work together
Old Feb 10, 2014 | 04:02 PM
  #453
Yes KIDJ is right! and when you drop the car (depending on how much you drop it) the specs will change
Old Feb 10, 2014 | 04:29 PM
  #454
fatty_gen2's Avatar
This is true. That's why i said "offset permitting"
His concern were the fenders. Roll or not.
Let's say its a stretched tire and no fender gap set up.
18 x 9.5 +40 will be sunk in. The concern now will the inner wheel well, correct?
Old Feb 10, 2014 | 06:04 PM
  #455
KidJustin's Avatar
yes. but if he's worried about back space...you can either get a wheel that is 18x8.5+40 or go with a smaller offset like 18x9.5+30
both will give u the same results more or less
so you can't really say...this spec will determine this or that spec will determine that. they work together. (and i'm not saying ur wrong...because ur not...but to me saying "offset permitting" is just a confusing way to say they both work together)
Old Feb 13, 2014 | 09:02 PM
  #456
Sitnlo86's Avatar
I am trying to buy some new wheels 19" str 601 and I want to get 9.5" wide I was wondering if this is can be done. not sure on an offset or tire size to chose. The rims have a 2.75" lip I'm lowered on stechs and willing to roll fenders if necessary and I want it to be flush with the fenders maybe a little poke. I was considering to do staggered with 8.5 in front with 35 offset and 9.5 in rear with same offset I'm just not sure what that would look like. Can anyone help me out a bit? Thanks
Old Feb 14, 2014 | 08:04 PM
  #457
MistaB's Avatar
1. Rim size and offset - 18x8.75 +33 (front), 18x8.75 +20 (rear)
2. Tire size - Recommend one please for fitment?
3. Suspension Setup(Spring/Coils) and drop: Tein S-Tech
4. Willing/Rolled Fenders? No but willing if needed
Old Feb 16, 2014 | 10:35 PM
  #458
yardleyTC's Avatar
225/40/18. i think that this would be safe and it would clear very easily. I have a 3 inch drop with a similar wheel set up. i had to drop down to a 225/40 to ensure i stopped rubbing. you will be very close in the rear with a 20 offset. i have a 18x8.5 w/25 offset.
Old Feb 17, 2014 | 04:59 AM
  #459
conceptmat's Avatar
Default Size question
Would this size wheels fit on 2014 tC, and if they do, which offset/tires to choose for flush look?
SIZE BOLT PATTERN OFFSET
18 x 9 5 x 114.3 e+25
18 x 9 5 x 114.3 e+40 to +45
18 x 9 5 x 114.3 e+50
___
Old Feb 17, 2014 | 06:38 AM
  #460
jaguada's Avatar
E+40 to e+45. The wheels will fit but you might have to roll your fenders depending on how low you drop it (if you do).
