Will This Wheel fit? (Guide to Offsets and more)..
Old Feb 18, 2014 | 02:52 AM
  #461
conceptmat's Avatar
Thanks for reply. Which is more flush e40 or e45? I am planning to drop on either TRD or Eibach Pro
Old Feb 18, 2014 | 03:36 AM
  #462
jaguada's Avatar
e40's will look more flush, I haven't seen e40's on a 14' but I'm pretty sure it'll be close to flush. Yup, then you probably will have to roll your fenders, I barely fit my 18's with just a 1.5inch drop lol
Good luck, no problem bro!
Old Feb 18, 2014 | 07:24 PM
  #463
MistaB's Avatar
Originally Posted by yardleyTC
225/40/18. i think that this would be safe and it would clear very easily. I have a 3 inch drop with a similar wheel set up. i had to drop down to a 225/40 to ensure i stopped rubbing. you will be very close in the rear with a 20 offset. i have a 18x8.5 w/25 offset.
So the front will be fine? And if i roll the rear i should be good right?
Old Feb 18, 2014 | 09:17 PM
  #464
yardleyTC's Avatar
I only had to roll the rear and i was much lower than your set up will be. I did it just to be safe. I dont think there will be any issue clearing the front fender. if you do it might be if you were braking hard and turning on full lock it might rub. but thats about it
Old Feb 19, 2014 | 03:18 AM
  #465
conceptmat's Avatar
Still trying to choose the right ones.. How about this combination on TRD springs? I am trying to stay away from rolling fenders.
38 front / 40 rear Offset
Rim Diameter:
19
Rim Width:
8.5 Front & 9.5 Rear
Hub Bore:
60.1
Number of Bolts:
Bolt Pattern:
5x114.3
Old Mar 18, 2014 | 01:07 AM
  #466
camicaz7's Avatar
first of all hello guys , i check this forum often but just became a member . and i bought a 2014 tc back in december and now i`m looking for wheels and come to some work vs-xx
and i really want to know if this setup will work:
18x9 with 26 offset (will mount the stock tire)
thank you and sorry for my small introduction
Ps: english is not my first language , be nice
Old Mar 24, 2014 | 04:22 AM
  #467
itsleeyo's Avatar
1. Eneki T6S all around 18x8.5 +50 offset
2. 235/45/18
3. Eibach Sport line 1.5" ish drop
4. If necessary, if it is possible without rolling would be the best.
Will it rub ?
Old Mar 25, 2014 | 03:25 AM
  #468
yardleyTC's Avatar
2. 235/45/18
Will it rub ?
it will not rub, wow a +50 offset? that wheel is going to be tucked big time, i had a 18x8.5 +20 in the rear w/ 3 inch drop and it was almost flush. i didnt rub with a 225/40/18
Old Mar 25, 2014 | 03:26 AM
  #469
vincentwu817's Avatar
2. 235/45/18
Will it rub ?
With 50 offset you should research if it will clear the calipers.
Old Mar 25, 2014 | 03:40 AM
  #470
itsleeyo's Avatar
I wanted 18x8.5 +35mm but they said it will not fit probably I ordered them from tirerack. They said 18x8.5 +50mm would fit
Old Mar 25, 2014 | 03:44 AM
  #471
That spec will fit EASILY.
Old Mar 25, 2014 | 03:46 AM
  #472
itsleeyo's Avatar
Should i return them before I even open them and say I want the 18x8.5 +35 ?
I am running 235/45/18 on them
Old Mar 25, 2014 | 03:50 AM
  #473
Yea it will only stick out a centimeter and a half more.
Old Mar 25, 2014 | 03:52 AM
  #474
itsleeyo's Avatar
I shouldn't have took their "professional" advise cuz I was gonna do XXR 527 18x8.75 +25mm and I know that would work but they said it won't work and I would have to do some crazy modifications to make it work.
Will I rub with 18x8.5 +35 with 235/45/18 tho ? without fender being rolled or should i got with 18x8.5 +25? I just want to have the closest clearance without rubbing. which one is a good set up ?
Old Mar 25, 2014 | 06:15 PM
  #475
KidJustin's Avatar
DaYUUM/Scion Evolution
that's good as is.
I run 19x8.5+30 with 235/35/19. no fender modification, no rubbing, flush fitment. lowered on coilovers
your smaller wheel size, but increased sidewall should make it very similar to what I have. ur wheel will just tuck in 5mm. I doubt your as low or lower than me so your good with whatever suspension your running, especially since 18's are smaller
Old Mar 25, 2014 | 06:57 PM
  #476
itsleeyo's Avatar
that's good as is.
I am running on eibach sportline pro I think I might keep the 18x8.5 +50 I would have to wait til april 11th for the 18x8.5 +30 to come back in stock and I cannot wait that long. I might just buy either a 20mm or 15mm spacer to fit it. Besides I would have to pay about 100 each way for them to ship the new ones here and return the old ones
Old Mar 26, 2014 | 02:52 PM
  #477
jcraff3's Avatar
a lot to read but im going to ask anyway..i am getting ready to concider wheels and after looking i have this 1 question
--if i buy a rim set at 8x8..instead of the stock 8x7.5..and i decide to keep my tires (brand frigging new for 705) then can i be safe stretching them by .5? but on the flip side i will probably see the lip and dont really care for that look..but i am very curious someone help em out please?!!
clearly i can just sell my current wheels and tires as a set and make some money back but just wondering about all optins
Old Mar 27, 2014 | 03:33 AM
  #478
v_erge's Avatar
Originally Posted by VuDism
After work pics
Vu's pic is the best one I found in the thread of what I want.
I am trying to run this as well.
18x9+35
245/40 most likely
TRD springs
So, who else is running this, seems pretty safe to me, no issues from what I've seen in the thread. Thoughts?
Old Mar 27, 2014 | 03:45 AM
  #479
VuDism's Avatar
18x9+35
245/40 most likely
TRD springs
Should be fine.
I had factory tires on mind 225/45
Sent from my Nexus 4 using Tapatalk
Old Apr 23, 2014 | 08:02 PM
  #480
xtypezer0's Avatar
Hey just wanted to report my wheels in. Maybe this will help someone out..
I have XXR 522. 18 x 9 Front / 18 x 9.5 in the Rear.
Running 265 / 35 / 18 Tires all around.
