Will This Wheel fit? (Guide to Offsets and more)..
Old May 2, 2012 | 08:06 PM
  #141
KidJustin's Avatar
DaYUUM/Scion Evolution
Yuriy, you might want to add this to the first post. i found it VERY useful
http://www.rimsntires.com/specs.jsp
it has both rims and tires specs....the way i did it was compare the stock wheels/tires (225/45-18x7.5+35) so whatever wheel/tire combo i want
it gives u measurements in mm and in....the diagram changes as you change the options (including the offset)
it has weight, circumference, revs per mile, odo reading, and if it clears (based on general assumptions)
...the only it doesn't do is stretched tires (obviously). if the tire or wheel is to big for the other, it will automatically adjust.
Old May 2, 2012 | 08:47 PM
  #142
Scion202's Avatar
wow really nice
i just dont get why the hell their backspacing is wrong.......i have no idea where they get their numbers for it
Old May 2, 2012 | 08:58 PM
  #143
KidJustin's Avatar
Originally Posted by Scion202
wow really nice
yea not sure...i was also hoping that if they had backspacing they would also have front
but either way...i just looked at it as a comparison to stock. like if their back spacing is X mm off from stock...is that X mm enough to cause a problem or no?
Old May 6, 2012 | 07:22 PM
  #144
KidJustin's Avatar
20x8.5+38
20x10 custom offset (i think its +40)
fits with no issues, no fender rolling...just stretched tires (and not crazy stretched either)
Old May 6, 2012 | 09:06 PM
  #145
Backinblacktc2's Avatar
20x8.5+38
what tire size kj?
Old May 7, 2012 | 06:52 PM
  #146
KidJustin's Avatar
Originally Posted by Backinblacktc2
what tire size kj?
225x30
and 245x30
...but there was still room, so i could actually fit a bigger tire size so its not so stretched. i'm sure the rear could have gone 255 or maybe 265 and still have no issues
Old Jul 9, 2012 | 05:00 PM
  #147
KidJustin's Avatar
another calculator i found interesting...
http://www.jonathanrowny.com/page/offset-calculator
Old Jul 16, 2012 | 05:35 AM
  #148
NVtc2's Avatar
Default Tires?
Hey guys, been cruising these threads trying to get some new shoes. This thread is really helpful as far as wheel size, but I'm having a hard time finding tire info in addition to it. I understand I can fit a 9.5 wheel on, but I'm unsure of tire size that will fit with no problems. I will roll fenders if I have to but if not, all the better. Basically my question is this, I'm on TRD springs and looking to put on a 19x9.5 +32, and a 255/35/19 tire (I don't want to stretch). Will this be alright? I see 2tc has 19x9 with +40 and the same tire size but my wheels will be poking out about 1.4 cm more between the offset and the additional width, so I'm wondering if that difference will potentially be a problem. Thanks for the help.
Old Jul 16, 2012 | 08:48 AM
  #149
Scion202's Avatar
rear should be fine
front you will occasionally rub
since you said you're fine with rolling fenders i dont think you'll have any issues
maybe get sway bars so the springs dont compress as much during cornering and therefore dont cause rubbing
Old Jul 17, 2012 | 01:45 AM
  #150
scionchicop's Avatar
Yuriy,
I went 19x8.5 +30 on wheels
245/35/19 on tires
TRD drop
Can you confirm its a perfect fit? I'm pretty sure it is. Just want to be sure.
Thanks!
Old Jul 17, 2012 | 01:49 AM
  #151
PEwilly9's Avatar
thats what i am lookin to put on my tC...19x8.5 +30
didnt know what size tire tho. 245 is nice n wider and low pro enough. Im on ksports so height is adjustable. when u gettin em on? what are they?
Old Jul 17, 2012 | 01:50 AM
  #152
Scion202's Avatar
That will look sick!
front will may rub ocasionally but seem like very rarely if any
Old Jul 17, 2012 | 01:55 AM
  #153
Great! According to Nittos website, 245 is the widest we can go on a 19 inch wheel. I got the NT05's. Wanted grip for the turbo setup. The tires i have now suck, so i've been taking it easy. Keep spinning tires on my auto between shifts which is no good for tranny. I went with a five:ad rim. I should have them on tomorrow if all goes as planned. My wife threw a wrench in the plans but i'm gonna try to maneuver around that one to get them installed!!!
Old Jul 17, 2012 | 02:00 AM
  #154
Scion202's Avatar
Just looked at others with trds and they never complained about rubbing with the same or greater from space so I think front may not rub at all
I hope u got 5 spoke gun metal ones or the new s7 but still gun metal ftw!
And I think u meant to say 8.5 rim is suggested to have 245 tire not all 19 rims
Ppl with 19x9 usually get 255
I got 235/40 because I wanted mire sidewall
Old Jul 17, 2012 | 02:05 AM
  #155
I'm hoping i don't have to drop lower so i can, 1. save money and 2. eliminate some of the fender gap i have.
You're hopes have been realized. I indeed did go with the R5:F's in gunmetal. I've been wanting them since i first saw them. I ended up buying my enkei's on impulse. Hoping to have the new shoes on tomorrow.
Should've been more specific on the width. That is what i meant.
Old Aug 7, 2012 | 02:19 AM
  #156
Nec_Tc's Avatar
Ok guys, think I found a set of wheels i am gonna pull the trigger on just trying to figure out which offset/spec is better MB Weapons 18X8 Et 30 with 225/45/18 or 18X9 Et 38 with 235/40/18 ? Which one will workout better?
Old Aug 7, 2012 | 07:56 AM
  #157
Scion202's Avatar
18X9 Et 38 with 235/40/18 will look better
Old Sep 2, 2012 | 12:56 AM
  #158
Nec_Tc's Avatar
so guys, I got my wheels, 18x8 et 45 BBS CK In silver, might paint/powdercoat in anthracite later, got an amazing deal 235/45/18 tires
[/IMG]
Old Oct 2, 2012 | 09:13 PM
  #159
11tc2's Avatar
So i looked through this thread, but the calculation is mainly for 18" wheels. I am still not comfortable going out and buying wheels so I wanted to run it by you guys and see if this will fit out cars. I'm currently driving an 11 tC2 and the wheels I'm looking at are these:
http://esmwheels.com/access/esm-004-sl-19-p-99.html
I was particularly looking at the 19x9.5 and was wondering which offset i need to get. I would like them to be as flush to the body as possible. I'm not the biggest fan of wheels sticking out a lot. Thanks in advance.
___
Old Oct 4, 2012 | 04:46 PM
  #160
Scion202's Avatar
size of rim dont matter, as long as you keep the same overall tire diameter
go with +40 for safety to make sure you dont rub in the front, you also never mentioned if you gonna lower the car/roll fenders/stretch tires
After you get +40s you can always space em out to make the flushness perfect
