Will This Wheel fit? (Guide to Offsets and more)..
Old Oct 4, 2012 | 06:55 PM
  #161
11tc2's Avatar
Originally Posted by Scion202
size of rim dont matter, as long as you keep the same overall tire diameter
go with +40 for safety to make sure you dont rub in the front, you also never mentioned if you gonna lower the car/roll fenders/stretch tires
After you get +40s you can always space em out to make the flushness perfect
I do want to lower the car, and I would not mind rolling the fenders if I need to. The +40 will keep the wheel at the same place as stock or will it make it stick out more? If i read correctly i think the higher the offset the more in the wheel is, and the lower the more it sticks out. I might have this all wrong... For some reason i'm not grasping this offset thing...
Old Oct 4, 2012 | 07:45 PM
  #162
Scion202's Avatar
stock offset is +39
The higher the offset (like +45) the closer the wheel to the inside of the car
the lower the offset (+20) the closer it is to the fender
In your case with +40 you essentially keep the same offset but add 2" in width to the wheel. 1" goes towards the car and 1" goes towards the fender
To estimate what it would look like just imagine ur current stock wheels sticking out an inch
Old Oct 4, 2012 | 09:59 PM
  #163
11tc2's Avatar
^OK, so i took a look at it. I'm not sure, but if i do drop the car I'm almost certain that i will have to roll the fenders. This is of course just by looking at it. Even so i don't see how im gonna clear that fender. The back might be ok but the front looks like it might need to be rolled. What do you think?? Also u mentioned tires earlier. I do not want to stretch the tires too much, so what would be a good tire size for this application?
Old Oct 4, 2012 | 10:25 PM
  #164
Scion202's Avatar
rear will definately fit
front will depend on springs, at stock height you should be fine but with lowerings springs you will rub since they never stiff enough.
bottom line is get +40, and if you lower it you will have to roll fenders and get 235/35/19 tires
Old Oct 18, 2012 | 06:11 PM
  #165
devanb3's Avatar
im looking at putting speedy illusion rs 18x8s 45mm offset on my car now my question is if i understand all of thiss correctly my wheel will actually sit closer to the center of the car now if i want it to be flush ill need major spacers so what would i be looking at for spacers in order to get a 45mm offset to fit.....like 30mm back and 20mm front?? also can i put stock tires on that until i get new
Old Oct 18, 2012 | 07:36 PM
  #166
Scion202's Avatar
with those wheel the look will be identical to stock
ull need at least 15mm for front and 25mm for rear for spacers to look flush
yeah you can reuse the stock tires, they will be fines until they wear out, no safety issues there
Old Nov 7, 2012 | 10:13 PM
  #167
munoz_cement's Avatar
Hey, I'm a noob to all this and this thread has helped a lot.. Purchased a set of xxr 521 18x8.5 +25 the other day. With a stock height (trd lowering springs on its wAy) will you guys think I will have any issues I'm trying to get that flush look. And suggested tire size would be appreciated. Thanks
Old Nov 8, 2012 | 10:38 PM
  #168
rsingh216's Avatar
Looks like it will sick in.
Old Dec 3, 2012 | 11:41 PM
  #169
Bingoin337's Avatar
I have the stock 18x7.5 with 39et. Lowered with S Techs. I would like to throw some 15mm spacers in the front and 25mm in the rears. Would it I have a flush fitment?
Old Dec 4, 2012 | 03:44 AM
  #170
o TaGGeD o's Avatar
Exactly what I'm wantin to do I like the stock look let me know how it works
Old Dec 4, 2012 | 09:36 AM
  #171
Scion202's Avatar
front will rub, rear wont
front will rub during cornering because the springs arent stiff enough, if you had coilovers and had the same drop then youd have no problems
Old Dec 13, 2012 | 11:16 PM
  #172
Ace0211's Avatar
hey guys will 19x9.5 with a 25 offset fit in the front without rubbing
Old Dec 13, 2012 | 11:28 PM
  #173
Scion202's Avatar
depends on your suspension and ride height
Old Dec 13, 2012 | 11:30 PM
  #174
Ace0211's Avatar
its not lowered yet but i plan on lowering soon, will this offset poke out or set flush
Old Dec 13, 2012 | 11:46 PM
  #175
Scion202's Avatar
lowering on what?
are you willing to roll fenders and/or stretch tires
Old Dec 13, 2012 | 11:55 PM
  #176
Scion202's Avatar
and yes it will be 0.5" poke
stock wheel front spacing is roughly 5.6cm for them to be flush you neen 18-20mm spacer
so ~7.6cm front spacing will be flush, with your wheels front spacing will be 9.5cm!
Old Dec 21, 2012 | 08:56 AM
  #177
scion303's Avatar
SO I am planning on getting a 18x8 +35 offset and I'm on 1.5 front 1.8 rear! I don't care about looking flush or anything... whats the best tire size for me? 235/45 okay? Do i have to roll fenders?
Old Jan 15, 2013 | 03:58 AM
  #178
juancho's Avatar
New to the Scion tC2 stance scene, so maybe someone will help. I have these wheels I had in a previous vehicle will anyone be able to tell me if the fitment would be too wide or show a picture of a Scion with same wheel spec???
20x9.5 ET 10 Front & 20x10.5 ET 5 Rear
I Know I'll probably catch some heat for the size, but it is a touring coupe after all.
___
Attached Thumbnails Will This Wheel fit? (Guide to Offsets and more)..-ms3.jpg
Old Jan 15, 2013 | 12:41 PM
  #179
scionchicop's Avatar
Really doubt you can fit those. Nobody has done such an aggressive fitment. Mad props for the legit wheels though!
Old Jan 15, 2013 | 03:12 PM
  #180
k0ntr0lledka0s's Avatar
NEVER say never! lol im actually running 20x8.5 in the front and 20x10.5 in the back check, out my thread for pics bro https://www.scionlife.com/forums/showthread.php?t=219180
but do you plan on dropping it? if so you have to roll your fenders with those specs....and what are the offset of the wheels?
