2004 xA Rear wiper stuck on high speed..
Old 02-15-2019, 11:46 PM
Default 2004 xA Rear wiper stuck on high speed..
OK, first time having an electrical issue with my xA after 6 years of ownership, my rear wiper seems to be "stuck" on the wash speed even when I'm not using that and if I click to the wash setting it doesn't do anything from "ON".
If I use the wash from the off position it does work, but the instant I put it to on from off it is going at the wash speed...
Please...help, before I take a 3/4 breaker bar to the f♡*&er!!!
Sticky How To Advanced Search SL (Scion Life)
______________________________
Last edited by MR_LUV; 02-16-2019 at 01:54 AM. Reason: Moved to Correct Forum by Administrator
Lune187 is offline
Old 02-16-2019, 02:17 PM
You can remove the rear wiper arm. That will buy you some aggravation-free time to check the wire harness, motor and switch.
The symptoms are constant, not intermittent. You can temporarily rule out a faulty wire harness.
According to the 2006 xA Washer & Wiper pdf, the only motor problems are the auto-stop position and total motor failure. As you're experiencing neither of these symptoms, it sounds like a bad switch. Unfortunately, the switch test procedure is lengthy. You have to remove the switch and test the ohm readings of multiple pins on the switch connector.
62Fender is offline
Old 02-20-2019, 06:58 PM
Big_Jim's Avatar
I'd bet that there is an issue with the stalk on the steering column.
Link for an xB, but is the same as the xA.
Big_Jim is offline
asurjc
02-28-2018 11:48 PM
jablackw
01-27-2012 03:30 AM
DirtyAstronaut
25
07-28-2011 02:02 PM
Marvy22
Scion xA Aero & Exterior
05-21-2009 12:10 AM
homerdash
06-11-2005 02:42 AM
Quick Reply: 2004 xA Rear wiper stuck on high speed..
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
