Installing Non-OEM foglights 2006 Scion xA
https://www.ebay.com/itm/White-Yello...-127632-2357-0
The only thing is, it doesn't have the plastic insert beauty rings. The cheapest I can find these inserts online is around $86 for both.
I think I'm just going to modify the plastic fillers for now. Then I'll just use my own wiring harness.
Has anyone tried this kind of install?
___
Should be pretty simple
1. cut hole in grill for fog lights. Hole-saw of matching diameter should work well.
2a. install wiring-harness. Start from both ends and work toward each other. Install switch inside cabin, run wiring out to engine-compartment. Install wiring at lights and work back towards battery and wiring from inside cabin.
or...
2b. look for factory fog-light wiring. Many cars have them pre-installed.
or...
I found the Toyota fog light kit online for under $100 shipped. Comes with everything, and good instructions. I ordered and installed just a few months ago.
There's a sticky thread for this, too. Here's link to kit I bought.
https://www.sparksparts.com/v-2006-s...terior--lights
niks_scion
Jul 15, 2005 10:46 PM
