2004-2006.5 [NCP61]
passenger side mirror turn signal light 2006 xA
Old 07-14-2009, 04:17 AM
thelittleone's Avatar
Default passenger side mirror turn signal light 2006 xA
Has anyone had to replace this?
If so, how do you go about it?
Thanks
thelittleone is offline
Old 08-06-2009, 11:21 PM
Xetronic's Avatar
Correct me if I'm wrong.
I think all you need to do is remove the black triangle on the inside of the door that houses the tweeter for your radio. (Should pull right off as it has just a plastic plug holding it in 06')There will be a plug that needs to be unpluged and then a few bolts to unscrew and it should pop right off.
Just install the new one, bolt it up and plug in the wire harness.
Xetronic is offline
Old 08-06-2009, 11:35 PM
SquallLHeart's Avatar
... that's to remove the entire side mirror.. which was not asked.
take a look at this:
https://www.scionlife.com/forums/tc-tech-diy-1818/mirror-turn-signal-change-24700/
you need to cut that sucker open.
SquallLHeart is offline
Old 08-11-2009, 11:19 PM
STEELBREEZE's Avatar
That write up is on a TC mirror. I believe an 06 XA does not use LEDs and the bulb can be replaced without the cutting. The rest of the dismantle is close to the same though.
STEELBREEZE is offline
Old 11-01-2009, 08:37 PM
polo3312's Avatar
The xA mirror and the tC mirrors ARE the same! I had the dealer change mine and $$$$. Much luck on doing yourself!
polo3312 is offline
Old 11-04-2009, 03:34 AM
Team XcelsiA
xSTANDxSTRONGx's Avatar
'06 xA, and all year tC have the same mirrors, I just saw the inside of one, and there is soldering required I think.
xSTANDxSTRONGx is offline
Old 10-14-2010, 04:32 PM
Axist2's Avatar
thats soo cool. great diy
Axist2 is offline
xBSciontist
06-18-2019 03:06 PM
shawnb41
01-28-2015 05:17 AM
mischman
01-14-2015 06:07 PM
minter66
12-15-2014 01:45 PM
Opr8r
20
02-25-2004 11:29 PM
Quick Reply: passenger side mirror turn signal light 2006 xA
