Secondary O2 sensor where does the...?
Where does the plug (connector) end go to? Ya know, the one inside the hole. I need to replace it, as 2 of the wires have cuts in the insulation and the wires oxidized through. Can't find where it connects to. Is it inside the car? Can't really see up in the hole either (:P)
Thanks in advance for your assistance. BMan |
I found the answer myself from a mechanic on a Honda site. Hope this helps you if you are replacing the secondary (downstream) O2 sensor. It helped me.
http://www.justanswer.com/honda/2y7c...or-access.html |
rear o2 connection; under console . . .
2005 scion xa rear o2 connector is located under console on passenger side at base of shifter on an auto matic. Only had to remove console and boom there was connector. Had a gray and black wire too FWIW.
OMG I have been looking every to see where this thing hooks up to inside the car.
