04 xA won't turn over
Old 09-19-2017, 06:59 AM
johnnyj09's Avatar
Default 04 xA won't turn over
So I went to get gas today car was running fine went in to get a drink came out and the car wont start it tired once then stopped just had a starter put in February the battery is fine.
When the key is out the ABS light and over heat light are dimly lite. I started to pull the starter but the day got away from me. What could it be? The starter relay clicks but that's where the power seems to stop
johnnyj09 is offline
Old 10-01-2017, 01:58 PM
Stames's Avatar
I realize it has been nearly two weeks and you've probably got this figured out.
I would look first at your battery connections, and the connections to the starter. I've had a loose ground cause everything you mentioned in your post.
Stames is offline
