1NZ-FE: Stock sensor types? Crank position, MAF, etc.
I am working on a Megasquirt to manage my xA's engine. I need info about the stock sensors to see whether I can use them with the MS, otherwise, I will have to replace or add new ones. Replacing or adding is easier, but could make switching back to the stock ECU difficult.
I have the wiring manual, but that only helps get a basic idea of things and the wire colours.
Right now, I need info on the tach output: the Crankshaft Position Sensor.
I need to know whether it is a Hall Effect, Variable Reluctance, Optical, etc. type of sensor.
Anybody here have any info or know where I could get it?
If you have info on other parts of the engine, such as EGO, TPS, and fuel injectors, please speak up.
Thanks
Thanks
kleecker
Scion xB 2nd-Gen Wheel & Tire
05-22-2016 06:10 AM
cid_mcdp
01-05-2015 02:45 PM
darkshadowofxdeath
12-03-2014 06:59 PM
