1st gen xb ckp issue swappd 2 still have problem..
Old Jun 12, 2023 | 05:22 PM
DexTheTech's Avatar
Question 1st gen xb ckp issue swappd 2 still have problem..
06 xb ckp code came up car runs, but bucks when im driving at higher speeds. And def after it is warmed up. No misfire count. Swappd the ckp sensor with one out of another runnning motor same prob. Bought a new one .. still the same prob. Did a wire trace and cl all the way to pcm. No corosion no open or frayed wiring. Even ohmd it..... so after all thst i went searchin and what i came up with is either a. The ckp sensor plate or the tooth gear has a crack which alldata says replace crankshaft.. (engine)... Anyone ran into this problem?? 160,ooo mi im soon to break it down to see this plate situation. Please lmk if anyone have any insight on this. Thanx
Old Jun 14, 2023 | 02:18 AM
RichBinAZ's Avatar
Did you put the original sensor out of your car into the running car and see if the problem moved?
What other tests have you done on the engine and fuel system?
Old Jun 14, 2023 | 03:36 PM
DexTheTech's Avatar
It was an running engine out of another scion. Not in vehicle no more. As far as other tests. Nothing else as of yet. My next is fuel psi and pull the fuel filter. Only reason i didnt do it yet because of the specific ckp code that i have and the driveability issue im having. Now it has 160 and dont kno the last time the pump and filter was changed. Im trying to make sure that the ckp sensor plate is or is not the issue.
Old Jun 15, 2023 | 10:50 AM
RichBinAZ's Avatar
There is this sticky about the crank position sensor, but I don't think it will help in your situation
https://www.scionlife.com/forums/sci...sensor-235733/
I suppose you could take the sensor out and look into the hole while slowly turning the crank shaft by hand?? Not sure how much you could see though.
Old Jun 16, 2023 | 05:56 PM
DexTheTech's Avatar
Thanx ill do that .. i was goin to break it down . The front section just see the whats going on. Being that is behind the cover all the old burnt oil probably is messing with reading from the sensor.. ill ck the link jic thanx
Old Jun 22, 2023 | 03:59 AM
sh0rtlife's Avatar
are you getting any excessive engine rattle? that sounds like vvt noise? or slight chain noise?
im asking as my wife bought her yaris NEW, complained about rattles to the dealer for MANY years untill it wasnt under warranty, with alot of the stupidest reasons for the noise
ffast forward to earlier this year
i was blowing crank pots and couldnt figure out why, one might last a day one might last weeks, but i could swap an old one back in and maybe get another week out of it...there was no sense of it..untilli pulled one out covered in shavings?!?!?!?
it seems the FACTORY failed to lock down the timing guides, and slowly but eventually all 4 bolts eventually backed out.1 by 1 by 1.. and one of the bolts had been kicking up onto the sensor and smacking the crank....ill happily post the carnage pics..and yes its the same 1.5 in these xb's only real change is the drive by wire TB
fwiw the chain STILL has its stretch indicator marks on it...but is a full link longer, the crank damage is WILD at the crank pot but since a full timing swap ive been trouble free for 4 months or so and about 8000 miles...the amount of metal i flushed from the engine is wild....120k miles on it too
Old Jul 14, 2023 | 11:42 AM
HeatherHollins's Avatar
Thank you for the advice, I will keep it in my mind.Dive into the world of computers with a variety of free essay examples available on this https://writinguniverse.com/free-ess...ples/computer/ website. Explore the evolution, impact, and applications of computer technology through these insightful essays
rockergal89
49
Dec 19, 2015 02:27 PM
mike93civic
Mar 3, 2012 11:17 PM
NewDolphin
May 10, 2011 02:01 AM
turner
Apr 23, 2008 03:58 PM
Archngl
21
Aug 19, 2007 12:09 PM
