2006 xB A/C problems
My AC will cool good sometimes then just quit. Then it will work fine, on and off.
I have replaced the compressor and still have the same problem. Something is failing intermittently.
Anybody found the fix for this problem?
Not completely familiar with the xB systems but most have a high pressure and low pressure cut off that could be tripping and later resetting making it intermittent. If you just replaced the compressor and moved your other controls over, this might be the issue.
Assuming you have the proper charge in the system?
billettesbox
03-02-2014 02:51 PM
