Fuel Pump help
Fuel Pump help
I have a 06 Scion xA. My car has been sitting for about 2 yrs. I went to get it back running and noticed I was not getting gas to the injectors. I located the fuel pump and tested the plug and I'm getting no power.
What should I check to see where my power problem may be. Ive done checked all the small fuses and a couple relays. Any help would be greatly appreciated.
*Moved to Correct Forum by Administrator. Please Do Not Post Technical Questions in the Introduction Forum!
______________________________
Last edited by MR_LUV; 09-10-2018 at 08:15 PM. Reason: Moved to Correct Forum by Administrator
Sometimes there's more than one fuse/relay box.
One under the hood and one inside the car.
The lid to either should have a diagram of what each fuse & relay goes to.
It's hard to check a relay but you can try swapping relays from another slot to see if the harness going to the pump gets any power then
yamaha16bw
61
10-05-2017 02:39 PM
GetSlideways
Scion xD Drivetrain & Power
03-16-2015 11:30 PM
