5sp - Has anyone changed ratio?
Old May 20, 2005 | 03:14 PM
eggie's Avatar
Default 5sp - Has anyone changed ratio?
Just curious if it is even possible to change the gearing? Maybe even just 5 gear to a higher ratio.
Old May 20, 2005 | 10:05 PM
jct's Avatar
jct
well i keep thinking about it but i like my ratios very zippy or peppy or what ever
the easist way to do it is just swap out trannys with the echo that way you can save a couple of bucks
Old May 23, 2005 | 07:50 PM
fireballfish's Avatar
Default Re: 5sp - Has anyone changed ratio?
the echo tranny is geared higher... might be worth a try if you're willing to spend the cash
Old May 23, 2005 | 07:52 PM
dgHotLava's Avatar
doing it right now...
got held back last week 'cause i was sick...
Old May 23, 2005 | 07:56 PM
dgHotLava's Avatar
Originally Posted by hornet_on_flower
....the easist way to do it is just swap out trannys with the echo that way you can save a couple of bucks
you can't swap the whole tranny. they have diff housings (and mounts)
Old May 23, 2005 | 08:00 PM
eggie's Avatar
Is a shop doing it or are you? How long and how much?
Old May 23, 2005 | 08:13 PM
hotbox05's Avatar
yeah that's how our heavier 108 hp cars are faster than the lighter 108 hp echo's
Old May 23, 2005 | 08:32 PM
dgHotLava's Avatar
i am doing some parts and a shop is doing the rest...
i don't feel comfortable working in a transmission so i want some help...
you can take the whole gear set and use them (the 4th and 5th gears are diff)
you also need to watch what echo gears you get...diff models have diff ratios.
i will be doing the tear down (remove the tranny, bring it to the tranny shop. break it down)
then i will step back and watch a pro...
i will put it back once its finished and see how it turns out...
price wise i don't know yet...
used tranny 300...
labor to remove and reinstall tranny (if shop was doing)...400
labor to do the gear swaps...including new bearings...800-900
LSD 900
synth fluids...35
new flywheel 500
new clutch 250
next i will be looking into the drive shafts and CV's
Old May 23, 2005 | 08:38 PM
eggie's Avatar
So basically alot of $$
Old May 23, 2005 | 08:41 PM
eggie's Avatar
??? Actually I was more concerned with freeway driving. If I can get 5th gear around 2.8-3g doing 70-75 that would help my MPG as I drive alot.
Old May 23, 2005 | 10:56 PM
dgHotLava's Avatar
i have done the calculations...
at 80 mph....i'll be turning 3400 rpm (right at the start of the power band)
anything lower and you'll be pushing the pedal too hard to save fuel...
Old May 23, 2005 | 11:22 PM
hotbox05's Avatar
thats alot of money hmm . i wonder how much just for a upgraded clutch and lsd?
Old May 24, 2005 | 10:17 AM
dgHotLava's Avatar
the clutch is about 400 for labor
and whatever the cost of the clutch is...
the LSD requires that you tear down the transmission...looking at 600-800 plus the LSD 880...if you don't do it at the same time as the clutch add another 400 to drop the tranny and reinstall it.
Old May 24, 2005 | 10:41 AM
hotbox05's Avatar
damn that's too much money. for only what like 150whp or so?
Old May 24, 2005 | 11:00 AM
dgHotLava's Avatar
the gears won't make HP
its done to increase MPG or take better use of the power band
Old May 24, 2005 | 02:52 PM
eggie's Avatar
Still alot of $$ for mybudget, but please keep me posted none the less.
Old May 24, 2005 | 03:48 PM
dgHotLava's Avatar
anytime you crack open the tranny or motor you are getting up in money...
i don't expect a lot of people to do this.
i will have my own write up when its done...
Old May 24, 2005 | 07:51 PM
hotbox05's Avatar
lol nah I know I meant all that work for a car that only has approx 150whp.
Old May 24, 2005 | 08:00 PM
dgHotLava's Avatar
it is a lot of work....
i am just a fool that has nothing better to do...LOL
Old May 24, 2005 | 08:17 PM
TheScionicMan's Avatar
??? Actually I was more concerned with freeway driving. If I can get ... around 2.8-3g doing 70-75 that would help my MPG as I drive alot.
There's an easy solution for that - swap in the auto tranny...
