Air "Compressor" prob. broke!! Is Pulley the culp
Old 07-05-2007, 08:07 AM
INFINI's Avatar
Originally Posted by uber-xA-RS2
Are we talking about the condensor or the compressor?
Condensor: Large radiator like structure in front of the vehicles cooling radiator and is used as a heat exchanger for the compressed coolant.
Compressor: Heart of the AC system, and is a belt driven accessory located underneath the 1NZFE alternator.
condenser
INFINI is offline
Old 07-05-2007, 08:10 AM
INFINI's Avatar
Originally Posted by Tomas
Toyota (Scion) recommends that you only use a "Top Tier" gasoline in any of their US distributed vehicles since those not certified to that standard do not contain enough detergents, etc. to keep our engines happy in the long haul.
It costs a little more to fill up, but it prevents a lot of problems down the road. (Do a search for top tier here on ScionLife for some discussions on this.)
For just the quickie list of acceptable fuels, go here:
http://www.toptiergas.com/retailers.html
Using an appropriate Top Tier gasoline you should do fine with 87 octane, unless you already have deposits built up in the engine.
Good luck on getting the condenser all patched up and the system re-filled!
Tom
Thanks for the link. It's been sounding MUCHO better only a day or so after I put the good gas
No more Arco for me
INFINI is offline
Old 07-07-2007, 07:40 PM
INFINI's Avatar
KK well so far no cold air coming out The Air condenser has pressure now that is was welded, but our attempt at waisting like 2 cans of Freon failed to produce any results.
I have to find an Auto Air conditioner specialist cause I am spinning my wheels here. Anyone know one??
INFINI is offline
Old 07-08-2007, 12:37 AM
hotbox05's Avatar
91 does not make this car run better.....
hotbox05 is offline
Old 07-08-2007, 12:39 AM
hotbox05's Avatar
when I bought my car i was told it uses the new freonless ac system . I know other new toyota's use that system , dunno if the scions do or not .
hotbox05 is offline
Old 07-08-2007, 12:53 AM
Admin Emeritus
Tomas's Avatar
Yeah, the Scions don't use Freon - they use one of the newer high-tech (but less efficient) coolants.
Refrigerant: HFC–134a (R134a).
Tomas is offline
Old 07-08-2007, 01:01 AM
INFINI's Avatar
YES!!!! I mean R134a Refrigerant!
INFINI is offline
Old 07-08-2007, 01:02 AM
INFINI's Avatar
INFINI is offline
INFINI's Avatar
Correction:
KK well so far no cold air coming out The Air condenser has pressure now that is was welded, but our attempt at waisting like 2 cans of Refrigerant failed to produce any results.
INFINI is offline
Old 07-08-2007, 01:15 AM
Admin Emeritus
Tomas's Avatar
Yeah...
Some Info
Tomas is offline
Old 07-08-2007, 01:26 AM
INFINI's Avatar
MAN! That was sum delicious Pizza. I got that printed already and will be reading it while I send it over to my Mechanic friend to see if we skipped any of these steps
INFINI is offline
Old 07-09-2007, 12:30 PM
vintage42's Avatar
Yeah but using 87 made my car rattle so loud it was embarrassing to drive. I was going to the cheapest gas station I could find Arco and such. The mechanics said that in the long run it can do damage to your engine and is not worth the few bucks saved at the pump.
Scion says 87 is best:
Reply-To: Scion <scion_mail@scion.com>
Date: Wed, 06 Sep 2006 16:09:12 -0700 (PDT)
To: <me@insightbb.com>
Subject: Scion xB horsepower and torque [Incident: 060901-000071]
Response (Vernon)09/06/2006 04:09 PM
… The vehicle is engineered and tested using 87 octane fuel. We recommend that fuel for optimum performance, reliability, and fuel economy on the vehicle. The vehicle does make the same power at maximum throttle position on 87 octane as it would on higher octane fuel.
If your engine was knocking, maybe your octane was below 87 or your knock sensor is not working?
The Owners Manual, Section 2, Page 114 says:
OCTANE RATING
Select Octane Rating 87... or higher.
Use of unleaded gasoline with an octane rating or research octane number lower than (87 octane) stated above will cause persistent heavy knocking. If it is severe, this will lead to engine damage.
Tech Literature:
DIAGNOSTICS - SFI SYST
DTC P0325 - KNOCK SENSOR 1 CIRCUIT - CIRCUIT DESCRIPTION
Knock sensor is fitted on the cylinder block to detect the engine knocking. This sensor contains a piezoelectric element which generates a voltage when it becomes deformed, which occurs when the cylinder block vibrates due to knocking. If engine knocking occurs, the ignition timing is delayed to suppress it.
Or maybe what you heard was a physical rattle not related to octane or knocking.
vintage42 is offline
Old 07-09-2007, 04:15 PM
ajayaitch's Avatar
Tomas pointed you to the top-tier site, so I won't bother repeating it.
Carbon buildup on the valve stems, heads or piston tops can effectively raise compression and cause hot spots, both of which lead to pre-ignition, or pinging.
10k miles of crappy gas is all it takes. The knock sensor may not be able to compensate if it is severe.
ajayaitch is offline
INFINI's Avatar
I guess then the quality of the 87 is important. I dunno but as soon as I started putting higher octane gas NOT from the el cheapo stations the sounds took a day and were gone. I guess getting 87 at shell or 76 will be my next test.
INFINI is offline
Old 07-09-2007, 09:34 PM
INFINI's Avatar
UPDATE:
The AC specialist says his diagnosis is a bad air compressor now
I am starting to get a eye twitch!! Back to the dealer to see if it's under warranty!!!!!!!!!
INFINI is offline
Old 07-10-2007, 08:28 PM
hotbox05's Avatar
gonna be hard to warranty the ac system after you've allready tried fixing it and possibly "messed up" stuff in their eyes at least , best of luck.
hotbox05 is offline
Old 07-11-2007, 06:30 AM
INFINI's Avatar
Actually the only way THEY would see it MAYBE as warrantied were if I spend the $850 to replace the condenser and then find that the Compressor was screwed and that is another $1000 that of course would be NOT UNDER WARRANTY I am sure. Lying SOB's gave me the run around today and they could not even find the problem. I really wish I could swear on these forums right now.
So it does not matter if I played there BS game or played my way they will come up with an excuse why it's nit under warranty in the middle of So Cal where I will have NO DAMN AC!!!!!!
Scion and Toyota might have lost a long term customer over a rock on the road.
I love the term "in there eyes" cause it's really another set of words for "Not under Warranty".
Obviously I am a little upset and do not think this is right really. But such is life.
INFINI is offline
Old 07-11-2007, 07:21 AM
Admin Emeritus
Tomas's Avatar
Remember, a warranty is the company saying they built the car right, out of quality parts, and it was in good condition when it left the factory - if it's wasn't, they will fix it.
It is NOT a promise to fix anything that goes wrong, for whatever reason, forever.
There is a VERY good chance that getting a puncture in the condenser, bleeding all the refrigerant and lubricant out of the system, then running the compressor in that condition for an extended time could damage the compressor. This is in NO way the fault of the manufacturer - it was damage after it was sold, not a factory error.
Yeah, it would be nice to have free repairs for life, but it isn't going to happen unless you spend one Hell of a lot more for a vehicle...
Good luck!
Tom
Tomas is offline
Old 07-11-2007, 07:37 AM
INFINI's Avatar
"Yeah, it would be nice to have free repairs for life, but it isn't going to happen unless you spend one Hell of a lot more for a vehicle..."
DUDE!!!! what do you work for a dealership?? I have had the car for 5K miles. I am not looking for free repairs for life and there are no conditions I made that made the car worse off other than drive it.
To me you make it sound like all the BS they gave me today was justified and it was BS what they told me. They look for how they are not responsible and put things off on me like they never even planned to deal with it.
Here are things they said:
"They could not find the problem that they diagnosed(even though I fixed what they told me was the original problem and there is no leak in the condenser)"
"they are really not used to having to deal with a fixed condenser rather than a brand new one that they install."
"that my pulley is a different diameter than the OEM (BIG BS on that) so they really can't tell whats' wrong."
Do these things really sound like professionals to you? EXPERTS in there field that work of Toyota and Scions every day??
If they had been clear with me like you had I might have bought into there hook but they were not.
NOTE: I am frustrated but I am reading your posts and not bashing anyone just cause they do not agree with me I am looking at as many angles as I can here to understand my situation.
INFINI is offline
Old 07-11-2007, 07:53 AM
TuningIsLife's Avatar
Find a pic of the OEM Pulley next to your pulley show that too them and go, I thought you said this was a different Diameter.
TuningIsLife is offline
Quick Reply: Air "Compressor" prob. broke!! Is Pulley the culp
