Automatic shift kits?
Does anyone know of companies that make them or a plug-in the recalibrates the shift points? I can't seem to find anyone that does and the ones that do are for late model muscle cars, etc.
no they do not i asked a few years ago and thats the answer that they gave me...
yeah, toyota makes one, it is called a manual transmission.
they make them for late model muscle cars because they didn't have computers and such. you don't have a muscle car, you have a fairly new car with an electronically controlled transmission with nifty features so that it will automatically select the best gear for the car to be in based on mph, engine rpms, throttle position, and engine load. you really can't improve on this other than say a valve body upgrade. |
I dropped a shift kit in a 4L60E electronically controlled
transmission.. worked great.. someone will make one oneday.. its basically a few springs and check valves, that are slightly stronger/bigger.. as soon as the demand for rebuilding these transmissions (by private shops) starts to happen, they tend to follow.. just too new right now, and all of them still under warranty.. demand is nill.. the trans is internally controlled differently, but it still comes down to an accumulator creating a hydraulic action in the tranny, changing the accumulators internal spring with a softer one, will cause firmer shifts... they also do make the complete part for you to buy, but our cars aren't "old" enough yet.. heres an example of one for a 83-98 toyota automatic tranny http://www.transmissionpartsusa.com/...00%2D09785523K these guys would be your best bet for contacting about this.. http://www.levelten.com/store/import...rts_toyota.htm |
back from the dead.... anyone make a shift kit yet?
This may be off but with the S-10 I had it was a electronic shift kit that wired into the ECM with 3 set points so I'm sure it could be done if you can find the pinout and figure what resistance to add.
Scott |
