Bad Motor Mounts?
I have a 2006 Scion xA and when the car is idle or in gear and stopped it vibrates really bad. It's not when the AC Drawing power. Was told it was the motor mounts so I replaced the mount above the passenger side wheel well still no change then the transmission mount and the vibration got even worse so then I took to the dealer and replaced the mount near the fire wall still no change. So I'm thinking that when I changed the trans mount I didn't get it from the dealer I got from auto store. Do I need dealer parts? And is there any way I could have put the mount in wrong? Cause when I took bolt that holds it in out it fell and I noticed there is a weight or bump stop welded on it does it matter which my it faces when installed?
_____ |
Any check engine lights?
Yes. But it's from the evap system and the vibration got worse after I replaced the trans mount
Sounds like you're down a spark plug. How many miles?
92,000
Tune her up and see if that helps.
That was the first thing I did when I bought the car
It sound like you may have a bad coil pack. See this video:
Originally Posted by XirtaXa
(Post 4161967)
I have a 2006 scion xa and when the car is idel or in gear and stopped it vibrates really bad. It's not when the AC Drawing power. Was told it was the motor mounts so I replaced the mount above the passenger side wheel well still no change then the tranmision mount and the vibration got even worse so then I took to the dealer and replaced the mount near the fire wall still no change. So I'm thinking that when I changed the trans mount I didn't get it from the dealer I got from auto store. Do I need dealer parts? And is there any way I could have put the mount in wrong? Cause when I took bolt that holds it in out it fell and I noticed there is a weight or bump stop welded on it does it matter which my it faces when installed?
Originally Posted by bluecollarguy
(Post 4176977)
Mine vibrates too, I thought it was normal for this little 4banger.
A mechanic told me I probably just need to change the mounts, as with the OP. |
If it revs up smooth (to about 2000 RPM) then you probably have a vacuum leak. or the PCV is stuck open.. both will cause rough idle but decent drivability... check the EVAP problem, have the codes scanned and replace parts, they may be causing vacuum leak.
I replaced all 3 mounts a few months back, and wow. I can sit at a traffic light in gear now. It wasn't the easiest but it was well worth the time.
I second Dstreak, possible stuck open PCV valve.
Sadly, I finally had to give up my 06 xB. I blew the engine but I found a pretty good mechanic and he replaced the head gasket for $1500 which I felt was fair. The car was running great again but the car had always been outside, these last 3 years in Florida, and yes, the heat/humidity and animal splats were quickly turning my beloved xB into a hooptie. some guy flew down from New York and paid me 5K cash, my odometer was only 72k because I've been retired for 10 years so we both were happy with the deal.
As it turned out a friend bought a 2017 Civic Si for his wife but she quickly got tired of driving a stick. It only had 5,000 miles on it and he sold it to me for 15K, seems like a very good deal. Plus, I moved the heck out of Florida to Vegas under an overhang so it won't take quite the beating the Florida swamp gave it. Unfortunately, this probably is my last post. I really loved that ole' xB, too bad they don't make something like the Gen 1 anymore because I would definitely buy it. The xB was by far the most fun and practical car I ever drove. Goodbye Everyone and Thank You! |
TSB EG035-07
There is a TSB for certain 2AZ-FE engines that causes rough idle. It is TSB EG035-07.
While Toyota "claims" it is only for certain 2007 Camry 2AZ-FE models, I highly doubt that, because I have read of several xB's, Camrys, and Scions having the same issue with rough vibration/idle while in gear. Apparently the charcoal canister becomes filled with liquid fuel and this is sucked into the intake through the evap lines. _________ |
Wish I was here sooner to read your post and help out.
Originally Posted by Redbaron2005
(Post 4294409)
thank you
Originally Posted by enduser62
(Post 4163371)
How to fix a Scion xB 2006 - YouTube |
I just got a used engine and had replaced all the main stuff I always keep my oil changed and love this car !
I feel for you as it makes me think of one day parting with my xB. Mine is manual as I have ADHD and that reminds me I am driving. ___ |
(Post 4161967)
_____ |
