"Big Throat" Throttle Body for xB?
Has any mfr. released a (larger venturi) throttle body for the xB yet? Maybe someone like Neuspeed...?
i think there is one for the echo should work for the scion
is it compatible though? Will it work with our ECU and not cause a check engine light to come on?
I'm getting between 450 to 550miles to a tank with my echo... |
Now what about smog? Wil it pass smog, because when I install something I am just to dam lazy to take it off. :D
Shouldn't cost to much to bore out the stock throttle body
and replace the valve. That may be the best way to go. What do you all think? Blu |
mmm...interesting proposal. But I would need to find a machine shop that has done it before. I don't want to be a quinea pig, but then again how much could you really bore out of our throttle bodies. They are pretty small as it is already. :? Very confusing
a throttle body should not cause a check engine light. i had my TB done at E.L. and it came out very nice.
does anyone have the price or the website. I might want to check that out! :D
Originally Posted by Wraith
yes I have a Apexi S-AFC and I aslo have more aggressive injectors but they're still the same flow rate which is 200cc ... The spray pattern on the injectors are alot more aggressive than the stock ones...
| All times are GMT. The time now is 07:14 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
