Bleeding air from Radiator lines..
Old Jan 24, 2007 | 01:23 AM
jwaj2002's Avatar
TOCC
Default Bleeding air from Radiator lines..
OK, I've searched, I need to know how to bleed the air out of the radiator lines on my xB its an 06.
Old Jan 24, 2007 | 01:36 AM
black_sand_box's Avatar
The Family
What did you do? Fill the radiator until it is full then start the car. As the coolant circulates it will push the air out. just make sure you keep it topped off.
Old Jan 24, 2007 | 01:48 AM
jwaj2002's Avatar
TOCC
ok I'm putting my killer glass in and I wanted to know how to bleed it, wasn't sure, so start it with the cap off?
Old Jan 24, 2007 | 01:53 AM
The Family
yeah,make sure you engine is cold when you start.
Old Jan 24, 2007 | 01:58 AM
jwaj2002's Avatar
TOCC
I will, I'll do it on my lunch break tomarrow
Old Jan 24, 2007 | 02:04 AM
The Family
Cool
Old Jan 24, 2007 | 02:13 AM
jwaj2002's Avatar
TOCC
how much anti freeze do you think I'm going to loose by doing this?
Old Jan 24, 2007 | 02:19 AM
The Family
Not sure but just buy a new gallon of 50/50 and you should be set.
Old Jan 24, 2007 | 02:39 AM
TerribleTed's Avatar
Good god don't buy 50/50. Buy regular unmixed antifreeze and the mix it 50/50 for use. When you buy premixed here it costs nearly 50% more than the non premixed. So for 50% more cash you get 50% less antifreeze. The added water in the premix or from my faucet is pretty dam cheap everywhere I am pretty sure.
Old Jan 24, 2007 | 02:49 AM
The Family
I agree, the only reason I said 50/50 was b/c he's doing it on his lunch break and he would have to fool with mixing. It is a more expensive alternative.
Old Jan 24, 2007 | 02:50 AM
jwaj2002's Avatar
TOCC
well I was told I wouldn't have to let out much, and I would like to try and just catch it all and reuse whats in there (toyota factory fluid is red, my led for my killer glass is red)
Old Jan 24, 2007 | 02:55 AM
The Family
I wouldn't try that. You are best, if you feel that way, to just go to the dealer and get some more.
Old Jan 24, 2007 | 02:58 AM
The Family
I wouldn't try that, it would probably hard to do and it would be hard to keep it clean. You are best, if you feel that way, to just go to the dealer and get some more. Now that will cost you.
Old Jan 24, 2007 | 03:10 AM
jwaj2002's Avatar
TOCC
yea I was afraid of that looks like I'll be installing it thursday then
Old Jan 24, 2007 | 03:18 AM
The Family
Wgy Thurs?
The Family
Why Thurs?
Old Jan 24, 2007 | 03:29 AM
jwaj2002's Avatar
TOCC
because I'll have to order the fluid I could do it tomarrow, just not sure, I found it cheaper to get the hose through the dealer ($10 vs 15 at the parts store) so the fluid shouldn't be $10 either
Old Jan 24, 2007 | 03:36 AM
The Family
Surely the dealer will have coolant in stock. They use it everyday.
Old Jan 24, 2007 | 03:43 AM
jwaj2002's Avatar
TOCC
yea they will, they just didn't have the hose, had to wait till today for that
Old Jan 24, 2007 | 03:46 AM
The Family
Why do you need a hose? Why aren't you using your existing hose?
