Cold air intake
I have a K&N Typhoon CAI and I thought the install was pretty easy. K&N's website has a PDF of the installation instructions if you want to get an idea of how the install will be like.
I think in terms of difficulty of any CAI, it will all be the same. I'm not sure if your looking for a CAI or an SR, but of the two, the SR is easier to install, mainly cause you don't have to take off your front wheel and get behind the wheel well to put on the filter.
I didn't remove my bumper. I just moved the battery back an inch (2 bolts losened and retightened once done) and removed the assembly (1 bolt and a hanger) that holds the stock intake's air inlet near the fender.
Installing the injen SR, which draws air from the fender, took me about 1 meticulous hour. I'm ****, and I'm sure I could have finished 15min earlier if I didn't triple check everything.
Originally Posted by Chimmy3
wow reading comprehension ppl... lol... he didn't ask for the easiest intake...
At least qualify the vote for the SR by saying that it pulls in the same air or something...
And there's a fair difference as to where the different intakes pull from. I'm working on a plan to see how much difference that really makes, but I will point out that the Injen CAI gets the filter the farthest away from the engine compartment...
What about a K&N typhoon, anyone know the difficulties or friendlyness behind these???
Then again, the AEM instructions (dealer version) make it seems fairly easy but it isn't. The instructions they give you are pretty crappy, but any intelligent person should be able to figure it out. To this day I still don't know how you can get the lower pipe in without unbolting the battery.
The injen short ram will give you more gains over any of the cold airs. The injen short ram is pretty much a cold air anyways, and its 100 dollars cheaper, the filter locates itself infront of the battery and plenty of cold air gets drawn up from the that whole left side bumber area. The quality is amazing and the gains are there. if you must waste your money and get a cold air intake i would get the Injen one.
