Crappy Miles Per Gallon! WHY?
Old 01-25-2010, 12:19 PM
  #121
vintage42's Avatar
Originally Posted by SentraSE-R
... I shift at 2000-2200 rpm... I rarely if ever need to use my brakes. Half the time, I roll through on green after the jackrabbits have tripped the light for me.... I reach the limit, then start cruising or coasting, milking downhills, hoping someone will enter traffic in front of me so I have an excuse to slow down and get better mileage...
I shift the same way, and am always aware of the other techniques but only practice them to a much lesser extent. I am by no means a hyper-miler, but can routinely get 35 mpg in city/suburban summer driving.
Best tank was 42.5 mpg holding 60 mph for a whole tank on an Interstate trip. If I had had the patience to hold 50 mph, the mpg would have been in the high 40's.
vintage42 is offline
Old 01-25-2010, 08:28 PM
  #122
bugandxbandme's Avatar
Actually, he did shift at 25-2800 rpms the whole last tank. Also, I do a lot of coasting when I drive it. We are hoping that as we continue to drive slower the mileage will improve more. Thanks for the tips, all.
bugandxbandme is offline
Old 01-26-2010, 02:04 AM
  #123
SentraSE-R's Avatar
Keep your top speed at 55 mph for a full tank on a long trip, and you'll surely top 40 mpg. Kudos to you and your husband for trying. I'm surprised you only got >32 mpg. Must have had a lot of stop and go short city trips.
SentraSE-R is offline
Old 01-27-2010, 06:21 PM
  #124
Looks like we might do ever better this tank. If the light doesn't come on before 310 miles or so I'll be happy.
By the way, are you (sentra se-r) running OEM plugs or something different? I know there are lots of threads on this subject but I was just wondering what your two cents was. There seems to be no consensus on whether spark plugs make much of a difference on your mpg, other than changing them regularly is important.
Old 01-27-2010, 06:46 PM
  #125
Music City Scions
bB2NER's Avatar
It's extreemly funny how people are so obsessed with stretching the fuel till their llight comes on instead of just going for a high average mpg over many tankfulls.
bB2NER is offline
Old 01-28-2010, 05:14 AM
  #126
SentraSE-R's Avatar
I'm running the original spark plugs in my xB. Spark plugs don't have any effect on mileage if they're the right type, gapped properly, and the ignition system is up to specs. OEM plugs are as good as, if not better than, most aftermarket plugs.
Old 01-28-2010, 05:33 AM
  #127
Music City Scions
bB2NER's Avatar
OEM plugs do alright but don't last very long. For max performance and mpgs it's hard to beat NGKs gapped at .044. Sure, they are more money but in the long run they will save you money.
bB2NER is offline
Old 01-29-2010, 05:39 PM
  #128
kwicslvr's Avatar
My last tank i was able to get 35.6mpg out of it. It is a 100 mile round trip to work for me and I kept it at 58-60mph. I typically go 65mph and average 30mpg in it. This is with 120,000 miles on the car and the 2 set of plugs (which I need to change out!)
kwicslvr is offline
Old 02-10-2010, 05:32 PM
  #129
ciscokid1970's Avatar
This is the first car I have owned where the mileage is dependent on so many things.
I use the same gas pump, at the same gas station just about every time. I let it fill until it auto shuts off. I divide the miles driven by the gallons purchased.
Just about all of my driving is 50 % stop and go, 50% highway.
OK here is my summary.
1. Engine Oil: I change my oil at 4k, use castrol synthetic. Big difference noticed between fresh engine oil and old oil. 29mpg before oil change, 31mpg after oil change. DO NOT overfill
2. Spark Plugs: I change my plugs at 20k. Before change 28mpg, after change 31mpg. First time I replaced with NGK 2460 Resistor plug (similar to original), next will try NGK 2087 V groove.
3. Air filter: I changed the air filter the week before the plugs...only noticed 1mpg difference...I guess the filter was not dirty enough. Use Puralator stock filter.
4. Trans Fluid: will change it at 40k...Lets see what happens, will use synthetic.
Check your air pressure...can affect +/- 1 mpg easy.
During the winter I have to let the engine warm up a little before start moving. This burns fuel and affects mileage.
ciscokid1970 is offline
Old 02-10-2010, 10:42 PM
  #130
Music City Scions
bB2NER's Avatar
The only thing I see holding you back are using stock plugs instead of Irridiums gapped at .044" and sill using paper airfilters. Switching to a drop in K&N, removing the air snorkle and getting the right plugs should be good for about 5 mpgs according to what I've seen over the last couple years.
You didn't mention what tire pressures you run. I keep them at about 34-35 psi.
bB2NER is offline
GoodVibes
21
05-22-2020 04:27 PM
knguyen
9
07-13-2019 10:31 PM
minter66
12-15-2014 01:45 PM
TonyM
12-15-2003 06:26 PM
Risen_Son_Racing
10-12-2003 01:21 AM
Quick Reply: Crappy Miles Per Gallon! WHY?
