DIY-Crankshaft Position Sensor
I consolidated my experience changing a CPS on a 2004 xB 1.5l 1NZ-FE:https://cimg6.ibsrv.net/gimg/www.sci...86160fb48e.jpg
Excellent DIY! Wonderful Illustrations!
Becomes a Sticky :) |
Why did you replace your sensor? Mine is all gunked up with oil and I have P0012 error. https://i.imgur.com/pt6KAsV.jpg https://i.imgur.com/qvMuWLV.jpg (upside down close up) ___ |
Also do you have to drain the oil before replacing? |
Here is the part in question. I cleaned it off a bit and got a better picture. Is that the crankshaft position sensor. The harness also doesn't look that good.
https://cimg2.ibsrv.net/gimg/www.sci...7e70b2cd62.jpg https://cimg3.ibsrv.net/gimg/www.sci...a9d07e479d.jpg |
from Esbe
You are correct that that is the crankshaft Position Sensor. You do not have to drain the oil to replace this.
I did not have a code but I bought the vehicle used with 130K and did not know how hard that little motor was made to work. I did preventative maintenance and among other parts I changed this and the VVT solenoid which could be your code source. The VVT solenoid will cost about $60 at this time, no need to change the oil, and is super easy to change. -- Reactor - Senior Member says "P0012 means: Camshaft Position "A" - Timing Over-Retarded. This code is not an indication of a bad camshaft position sensor. For that we have P0340" -- Here's your P0012 code explained and it mentions the VVT (or VCT) solenoid (code P0010) as a probable cause: https://www.yourmechanic.com/article...by-jay-safford If you decide to change the VVT solenoid, -- This guy does an excellent job of showing you how to change the VVT solenoid with lots of pictures: http://www.clubxb.com/forums/scion-x...ml#post1127425 After you remove the plastic top engine cover, here's my note sheet: https://cimg5.ibsrv.net/gimg/www.sci...64fe511d80.jpg |
Thanks a lot! I already did the OCV sensor swap so VVT and CPS will be next on my list. Do you have part numbers available? |
I'm sorry but the part costs twice what I mentioned previously. I'll edit the post.
Here's the part I installed a year ago and since then no issues with the part: STANDARD MOTOR PRODUCTS VVT162 {#1533021010, 1533021011, 1533021020} (Standard Replacement Here's where I got it from: https://www.rockauto.com/en/parts/st...actuator,12910 here's a general description of that product: http://eaccess.smpcorp.com/eCatalogs...16_JTF_VVT.pdf |
No worries, I’ll probably pick it up on eBay which their sales lately I should get a good discount. Do you also have the crankshaft position sensor part # handy? |
Crank Positoin Sensor Part #
Beck Arnley 180-0307 Crank Angle SensorI installed this a year ago and have had no issues with this part.Let us know how it goes with your repair. |
I was looking over the posts and if you replaced the OCV (oil control valve) you've replaced the VVT solenoid - same part different names.
In the second video at 4:20 take note of the mention of an 8mm hex bolt filter beneath the Oil Control ValveToyota 15678-21010 Oil Control Valve Filter https://parts.toyota.com/a/Scion__XB...04.html#15678A or |
Originally Posted by Esbe
(Post 4291057)
This will be the worst case for the P0012 : https://www.youtube.com/watch?v=vyp5_2i_3cA and https://www.youtube.com/watch?v=RrYbow6O9zI Otherwise, I have a case open with Toyota about the P0012 but that would require me to go to the dealership for an inspection. Thanks for sharing the part number. I ordered it already and will hopefully have it replaced later this week. Do you know anything about the Crankshaft Position Sensor wiring? Should I replace that wire or just clean it off with some Simple Green? ____ |
(Post 4291051)
(Post 4291056)
Okay. The part posted a picture of was not the Crankshaft Position Sensor, and I still don't know what it is. However, I did replace my crankshaft position sensor since I was there. Good thing I did, here's what it looked like:
https://cimg1.ibsrv.net/gimg/www.sci...c4c7e9ff9c.jpg I cleaned up the other sensor from the outside. I couldn't even get the locking mechanism to budge because the wiring is so snug. I'm still trying to figure out what this is and if it's easily replaceable: https://cimg0.ibsrv.net/gimg/www.sci...8963651ade.jpg https://cimg5.ibsrv.net/gimg/www.sci...dea8c9a63e.jpg |
Where is the crankshaft sensor on the Scion xB? I looked where the picture shows
Originally Posted by caliscion83
(Post 4291022)
Originally Posted by scwillbow
(Post 4292377)
Where is the crankshaft sensor located? I looked where the pic shows but doesn’t look like the replacement part Looking at RockAuto all of the replacement sensors look like the ones shown above: Crankshaft Position Sensor |
@MileHightC Hi, I got the Camshaft Position Sensor. I was removing the Air filter and the Battery (on Tuesday). I was looking on the engine driver side. Please let me know why there I can not find this part?
Thank you. https://cimg4.ibsrv.net/gimg/www.sci...4e6a269725.jpg Looks like the best part for the job!! https://cimg5.ibsrv.net/gimg/www.sci...7d59aff546.jpg I can not find where to install this in Scion xB 2004!!! Or to use on the key chain? ___ |
Originally Posted by Birsan
(Post 4306551)
Hi! Would there be a tutorial for crank sensor replacement for a 2015 xB? I'm stuck at removing the sensor cable behind the serpentine belt and alternator.
