Door AJAR light stays on
Old 12-12-2018, 10:25 PM
mlam90's Avatar
Default Door AJAR light stays on
Just bought a 04 Scion xB automatic, the light was not on when I bought the car, one morning opened the door and rear tail gate hatch and the light never came off after closing all doors, I already lubed all contacts, tighten the grounds on the rear hatch door, unscrew and re tighten all door switches, don’t think it’s a fuse, if it is what fuse would it be? Can’t find anything online; tried opening and closing all doors multiple times, unplugging battery, taking out the ecu fuse. Heard somewhere it could be the rear hatch door switch? Not sure. Any help would be appreciated!
mlam90 is offline
Old 01-21-2019, 04:31 AM
phatcyclist's Avatar
Your best diagnostic test will be to carefully remove each door switch, remove the plug on the back, and test between the contacts with a multimeter set to resistance or continuity. Check each with the switch "open" and then "closed". If you see one switch not having a difference in resistance/continuity between open and closed, that is your bad switch. If you check all the door switches and they all test out OK, then you're most likely looking at a failed hatch switch, which may be built into the latch assembly and might have to be replaced as a unit.
phatcyclist is offline
Notajerryskid
02-03-2016 11:39 AM
Nottingram
03-19-2014 04:02 PM
801tC
Scion tC 1G ICE & Interior
10-24-2011 03:11 AM
valkyrie6x6
10-27-2009 08:15 PM
camj979
10-31-2007 06:56 PM
Quick Reply: Door AJAR light stays on
