ecu
is the stability contorl and abs separate or linked to the ecu or not (im working on something)
Its built into car's ecu, if it comes factory with stability control. The ecu controls it by causing a misfire on a cylinder to allow for lower power output to get traction.
last i learned traction control uses your brakes not a misfire in the engine. otherwise i think you would have a code thrown from other sensors.
this can not be a misfire... BMW's do the engine control method...not my xB if trac control did the engine method, why does it communicate with the brake system? |
abs stops wheels from locking, traction control is a little different on all cars it does use feedback from the wheel speed sensors but it doesn't do the brake thing. It is controlled misfires not just random ones it kills the spark.
ever notice that your brake pedal losses pressure when trac alarm goes off? because the braking system for trac and stability is a 4 wheel completly proportioned electronicly controlled braking system. The vehicle uses sensor imputs to apply brakes in certain amounts at certain wheels. It uses a electronic proportioning valve and allows the brakes to be applied but only allows fluid to flow to certain brakes that is why there is not a complete loss of pedal pressure like if your brakes went out, but only a really light pedal. Along with that it controls the engine by spark cut or shut off, to decrease the amount of power output from the engine, not a controled misfire, but simular. Atleast that is how the 06 XB and XA is desighned but should be the same for all models and years.
DG, maybe because of your boost the TRAC system has to use more brakes than n/a would require, so thats what you feel. When my trac comes on it feels like my engine is collapsing.
for some reason i get a misfire code sometimes, when the CEL goes on for that so does the VSC and TRAC lights |
if your working on something and you need it off... which i don't recommend or suggest.. just unplug the fuse.. or if you have an xb just unplug the whole unit.. hint its under the shift boot.
Why dont you suggest turning it off indigo?
is trac control is onlee in the 06 xa's cuzz i dont remember having trac control on the 05 xa cuzz i can sit there and burn da tires till da street is filled with smoke unlike my box where i actually have to turn it off to even attempt it
I'm just making sure that I don't get blamed for any possible mistakes that you could encounter with doing this... not to mention how poorly the Xb handles without the vcs trac and abs.
does the echo ecu have abs?
if it did have ABS (like our xB) it would be a stand alone type.
our ABS is not in the ECU, rather it talks to it. our ECU is under/behind the glove box. the ABS is below the ash tray/ forward of the shifter console. 2 systems. |
