HOW TO: Remove and Paint Engine Valve Cover
Yes very nice!! Warning for TC owners the spark plug cable plastic holder on the right of the valve cover is a _____ I broke it while trying to remove the cover. No big though I cant wait to get my wrinkle red in the mail. I'll post pics.. I cant wait to put these on also just got them in!
take a look at steps 7 and 12...you'll see the gasket grove in 7 and with it back in place in 12.
of course you should make sure you don't nic the gasket or have it fall out of place when putting it back in...run the car for a min or two while looking for leaks around the gasket seems...
that's all I needed to know.
http://www.club-tc.com/forums/engine...lve-cover.html
This DIY recomended to use the black toyota silicone to hep seal everything but everyone I talked to never mentioned anything about the stuff so just thought I would ask.
nvm, I manned up and got it out lol
Is there a easy way to tell if your leaking oil because I think I'm leaking a bit from the back above the fuel rail. But I'm not sure if it's just crud or oil...if I am it's not a whole lot.
I broke several bolts with the given torque specs of 15lbs in the diy. Afterwards, I discovered that the actual specs are 8lbs for the short bolts and 2 nuts around the edge. 10lbs for the 2 long bolts in the middle. You may wish to update the first post.
Thanks. This really improved the look of my engine bay for a small amount of time and effort with very little cost.
