I want a REAL answer... Header Install... What bolts locally
Stores that I have nearby are.
Lowes, Home Depot, Pep Boys, Checker, and Autozone. I dont want to get mail ordered $17 bolts to connect my new header to the rest of the exhaust. If I want to just go to a hardware store and get some bolts what length and diameter do I need to get.
I only have one vehicle, so once I jack up the xB I cant take the bolts out, and take them to the hardware store to compare. I have to get them before starting the install process.
Which header you get ?
Is it threaded already ? If so use stock spring bolts.
If not go get bolts approx 4 1/2 inches long and nuts and lock washers to match and install away.
Any 3/8 " diameter bolt should work 3/8 x 16 x 4 1/2 long would work with matching nuts and washers. About say grade 8 , maybe even lesser.
you should be able to reuse the stock bolts
check this thread
http://www.xbsite.com/forum/thread-9....html#pid33526
check this thread
