Long Day’s Journey into Mufflers - xA Muffler Odyssey
I have played with mufflers before and come to realize that there is no free lunch…you can have relative quiet, with some flow restriction, or you can put on a freer flowing muffler and maybe pick up some power (some real power, plus that subjective jolt that comes from being able to rev more freely- where pulling to the redline seems easy instead of stifled). I’ve never been a fan of "sports car" sound, quite the opposite, I think it's true genius to have maximum power PLUS ultra quiet. Anyway, the one big negative about the stock Scion xA with a stick shift, is that at today's typical freeway speeds (75-80 mph) the engine is turning over at a whopping 4150 rpm (or higher, I can't see the tach that clearly). Now, the engine is ultra smooth and well balanced, so in a way it purrs at 75-80, but there is also a little bit of droning that seems to come in around 65 mph and doesn't depart until 80 mph. Which motivates me to kick it up to 80 mph to get past the drone, which isn't a good thing. In hindsight, I wish I'd ignored the drone, but I'd had recent success with an Echo by putting on a Dynomax 17709, now discontinued, which was a 7" round, 18" long, 2.25" inlet/outlet muffler. On the Echo, it was very quiet, but seemed to flow much better than stock. Keep in mind that the Echo, which was an automatic, had a much lower rpm at freeway speeds than the heavier, stick shift xA (even the xA automatic has much lower rpm). By the time I got the xA, the 17709 had been discontinued, but I managed to get a Dynomax 17710, identical in all respects except for 2.5" inlet/outlet. Well, the increased diameter coupled with the increased rpm meant a world of difference, and the first replacement muffler I tried was too loud, with a large drone in the cabin. The next muffler I tried was a Magnaflow 13650. That is a nice 6" round (much easier to fit, only 1" over the stock 5" diameter), with a 2" inlet/outlet (much closer to the 1.75" stock tubing) but with an 18" body (about 4" longer than stock). I figured, at that time, that a longer body would be quieter because there would be more muffler to quiet things down. This was the Magnaflow XL which is a three chambered, turbo (perforated interior tubing) design compared to the more usual Magnaflow straight through glass-packs. I figured the more conventional design would be quieter, certainly quieter than the Dynomax. WRONG! This was the loudest muffler I tried. Great sound, though, and if I never went over 35mph on the street, the one I'd keep. At freeway speed, though, it was really, really loud. Gave the most power, though. Although I had saved the stock factory muffler, instead of going back to stock, I decided to try a 1.75" inlet/outlet Walker Quiet flow, same body size as the late lamented Magnaflow. This was definitely quieter, but the least powerful. Finally, one muffler shop told me 1) don’t go up in tube size more than a 1/4 inch over stock, our you actually lose power; 2) don’t get a much larger (length or diameter) muffler, it can’t do its job right. So I ordered a Dynomax 17742, which is 6" round, but only a 14" body, and has 2" inlet outlet. This final muffler seems to do the trick. It has a nice sports car sound, especially in parking structures, but is very quiet at freeway speed, unless you are going uphill or get on the accelerator. I think it is actually noisier at all speeds than the stock muffler (or the Walker I tried) based on the radio volume levels I use, but doesn’t have the drone I was trying to get rid of before. Although it is a little louder at all speeds, the tone is very good, it lacks the "drone" peak, and wind and tire noise are still louder than the muffler on the freeway (the muffler isn't the biggest source of noise). On the other hand, the payback in performance and “sportability" is very great. I don't feel the motor is struggling to get past 4,000 rpm. It doesn't seem to "complain" in the last portion of the power band. (It is, however, a lot louder in this last section of the power band and this increase is relatively greater than the much more moderate increase in cruising loudness). In short the Dynomax 17742 seems to deliver what the TRD design does, at a fraction of the price. True, it's a weld on (instead of bolt-on, like the TRD) part, but the installation only ran me $30 with the welding and hanger fabrication, and the muffler itself only cost $39.95 from Summit Racing with free shipping. It's hard to beat that pricing. The xA feels like a little sports car with it's new muffler, I even find myself taking some curves faster, because I can hold it in lower gear longer without feeling like I am in the "forbidden zone" of rpm. I do wonder if throwing a downshift going around a corner is going to get more police attention, but I figure nowadays radar is what gets you, not subjective reaction. And I am still way far away from fitting any tuner profile (this isn't a "rice can" muffler and it has the stock tip). |
Wow, that was a good write up....
If only I could buy, weld, remove, and replace 4 different mufflers on my car to find the best one! :shock: Anyway thanks for sharing. I'll have to look into this! -THE DON |
Nice lil' write up
That's a great review! I have a few questions...
How bigger is it over the stock muffler? Does it hang lower? My xA is lowered about 2 inches and I'm worried about it scraping. I hope it won't cause what you've described is nearly exactly what I've been looking for. Also, do you have any other modifications on your xA? intake, header, ect... Thanks! |
Re: Long Day’s Journey into Mufflers - xA Muffler Odyssey
and those RPM's stay high! I have the "drone" too, but I still find it hard to believe that a sport muffler will help, and not just make it louder. I still need to ride in a scion with an exhaust with the windows down and stereo off to see how it really sounds inside the cabin. If it's too loud my girlfriend will go nuts! She used to hate my civic and made my vow to never put a "noisy thingy" on any of my new cars. :lol: -THE DON |
Nice write up dude :)
Your choices (Dynomax and Walker Quiet flow) was exactly what I was thinking about for after doing a lot of research through Google :) . Thanks a lot for testing the products and let us know. I might end up getting a Tanabe Hyper Medalian instead or a custom setup, according hotbox05 and squirrel's recommendation. Will see... |
Yeah which mods do you have on? Also are you running the manual tranny xA? The auto trannys on any scion is louder at freeway speeds. So I wonder what would work from walker for those. But yeah good write up on the topic.
have you tried Dynomax ultraflow SS? it is straigh through and it is quiet also. I had it on my 84 Nissan 200SX turbo. It is as queit as the stock.
thanks for the write-up. i was trying to find out what type of muffler i should go with. you made the choice easy. and to think, i wanted to go dual exhaust from a dual outlet . HUHHUHHUH
if you hear drone , just put some dynamat in the rear hatch area on the floor it will surprise you how much of a difference it makes.
A quick fix for droing muffler is to go to any place that sells auto parts, even Walmart, and you can buy Rubberrized undercoating in a spray can. You mihgt want to get 2 or 3 cans. What you do is spray this underneath your car around the muffler area and anywhere else that you feel will help reduce the noise. You can also remove interior pieces and spray the inside of you car. Beware though, it stinks so be prepared to let it dry and air out your car.
I have done both methods on my Del Sol and Protege 5. I know it works and is a much cheaper alt to Dynomat. yes is smells but the smell goes away. My Del Sol was a 13 sec 1/4 mile All motor beast with basically straight pipes. It was very very loud to say the least but this helped reduce noise in the car and also helped reduce vibrations. The good thing is the more cans of undercoat you use the more it works on reducing the drone and noise you get inside your car from the muffler. |
