MPG DROPPING.... :(
Hey guys another question; lately on my Scion Xa 05 i have been wasting double the amount of gas that i normally do.
I don't know what it is but its kinda of ____ing me off $36 a week is not cool i used to be able to do that in 2 weeks tops. I changed spark plugs last year around this time.... Tires have air on them perfect, there balance and all. I have an intake and filter is washed and clean. Oil only has about 2k on it and its syntactic. I ran out of ideas on what could be causing this..... Any help or suggestions will help greatly guys. Thanks,:cry: FL |
did you change your driving habit? do you now drive more in the city than on the highway? how about weight? are you carrying a lot of things in the car?
i read somewhere that the more ethinal they put in the gas the lower your avg mpg will be. could be the reason
Keep in mind about " winter gas "
clean you maf sensor change your PVC valve... and go on a diet
^^ and when did you 'clean' the filter? Was it an oil based cleaning system? Some oil may have gotten on the MAF Sensor, give it a cleaning with CRC cleaner or something to that effect.
Intake a SRI or CAI? Any more traffic than usual? Gas from a different station that usual? |
Hey guys nope driving habits stayed the same nothing changed. I will clean the MAF this weekend but i cleaned it a few months ago... :( and for intake i have a SRI which i clean the filter with water yearly as well... weird. Ill keep you posted thanks again all!
Originally Posted by FL21289
(Post 3808708)
Originally Posted by jct
(Post 3809007)
eh i was on the right track
(Post 3809007)
follow the vent hose from the air intake tube to the valve cover
Late Update guys.
But i replaced the Spark Plugs which were pretty much dirty. And also replaced the PCV valve which was also dirty like from oil or something. Boy what a difference those 2 parts did, feel like i got my power and gas back once again. Thanks you all like always for the help ;) |
Did you check your engine motor mounts? If they're worn and you're engine shakes when rev'd in N (as a test)... it's a waste of power/mpg.
