Oil Pressure Gauge? 2006 xB
Howdy, new to the group but long time 2006 xB owner. Purchased new in 2006, 156K on it. Oil pressure light is on. Just had oil changed and light went out. Now back on after only ten miles. ODB2 fob with Bluetooth Gauges does not support oil pressure in this 1st generation xB.
Should have checked that before buying ODB2 fob I guess. Homer Simpson moment for sure. Looking for thoughts on available oil pressure gauges, after market type. Can stay under the hood as far as I’m concerned. Just looking to find out what the actual oil pressure is.
Any thoughts or suggestions appreciated!
______________________________
Last edited by MR_LUV; 11-10-2018 at 04:16 PM. Reason: Moved to Correct Forum by Administrator
I'd suggest jumping on Summit Racing's website and you'll find any number of oil pressure gauges...could be the sensor going bad also, which would be a pretty easy fix. I don't know how much good an oil pressure gauge is going to do you under the hood, especially if you might have potential issues with low pressure. I'd want a gauge that I could see 'just in case'...
My advice would be to find the cause of the oil pressure light and address it appropriately.
tCing_U
07-13-2006 07:02 AM
ScionDad
09-20-2005 04:51 PM
