Power Loss - Issues with Throttle Response
Old 03-22-2019, 09:40 PM
Default Power Loss - Issues with Throttle Response
Hello,
I have a 06 Scion xA Manual Transmission.
I'm having issues with throttle response when I need to go fast.
If I'm just cruising around at low speeds I do not experience any issues. (Usually in the lower RPM's going up).
However, when I need to get going quickly, when I shift into the next gear and have the gas pedal floored...
The car revs up high, but the power is no longer there, it takes a second for it to start moving.
I've changed the spark plugs, ignition coils, fuel pump, fuel filter, fuel regulator and have cleaned the MAF sensor and Air Filter and have ran SeaFoam through it.
The fuel injectors seem fine.
My cousin mentioned the clutch might be going out, but I don't believe that to be true as I'm not experiencing any other issues related to the clutch or shifting for that matter.
No check engine or error codes.
Any thoughts or suggestions?
Steven4x4 is offline
Old 03-23-2019, 11:13 AM
2stroked's Avatar
Sounds like your clutch is slipping. When this happens, do you smell anything awful? A slipping clutch smells just like over-heated brakes.
2stroked is offline
Old 03-23-2019, 11:29 PM
No - Nothing smells.
However, if we take the shifting out of the equation.
Say, I'm in 3rd gear at 2.5-3 RPMs, if I try to floor it, the same thing happens, high rev, then a delayed throttle response.
So, I don't think that shifting is really even part of the problem anymore.
Old 03-24-2019, 11:39 AM
2stroked's Avatar
There's only two ways RPMs go up quickly in a standard transmission with the clutch engaged. The desired way is the car accelerates as fast as the gearing will allow. The other way is the clutch slips. From what you've described, you have the latter. Take it to a competent shop and have them drive it before you waste any more money throwing parts at it that it doesn't need.
2stroked is offline
Old 03-24-2019, 02:33 PM
Moderator
Moderator
Excellent advice and I'd agree that you have a slipping clutch...
MileHightC is offline
Old 03-25-2019, 05:29 PM
Thanks for all the feedback.
I'm not familiar with the term "Component Shop". Is there another name for it?
Old 03-25-2019, 07:30 PM
2stroked's Avatar
Competent shop. That's a shop that knows what they're doing.
2stroked is offline
Old 03-25-2019, 07:42 PM
Oops - That's embarrassing. Thanks for the correction.
Thanks for your help!
Old 03-25-2019, 09:55 PM
2stroked's Avatar
No problem. Let us know what you find.
2stroked is offline
influence
69
10-18-2006 03:13 AM
sensez
02-23-2006 07:53 AM
ASC
9
02-01-2006 05:14 AM
ignitionr34
13
09-07-2005 03:00 PM
joe52985
05-27-2004 07:27 PM
Quick Reply: Power Loss - Issues with Throttle Response
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
