Scion xB 2006 Alternator Question..
Is Scion xB 2006 Alternator is not straight because of the bracket?
Is that normal to all Scion xBs? *Moved to Correct Forum by Administrator Sticky Where to Post Your Question Sticky How To Advanced Search SL (Scion Life) ______________________________ |
I take it you mean the belt is not running straight on the pulleys?
Or is the alternator pulley sitting at an angle to the belt? The brackets are hard to bend so it is likely something else, like loose bolts. I cant remember if the alternator is rubber mounted or not - which can cause alignment issues |
Not rubber mounted. Has the alternator been replaced recently? Torqued down?
