Sounds like my clutch is falling a part! O_O
I've got about 77k on my 05. Ever since I bought the car (used at 50k), reverse has been a little off (if i don't play with the stick a little before goin to R, it grinds).
I've also done a couple of good burnouts (which I shouldn't have done ), and got stuck in mud and had to bust out the rev's (got to 60mph in 3rd without moving an inch).
Well, my c pedal feel is stiff now, and I get a little squeak when I push down.
When I let off the pedal, but before giving enough gas to rev up, it sounds like I get a lot of clanking from what I think is the pressure plate. When I hit a bump in the road, I get a similar "metal" clanking sound from the clutch area, like something is loose.
Will replacing the clutch fix the problem?
What can I do to fix the syncro on R?
1. there probably isn't a synchronizer on reverse. i'm not 100%, but on the tc, reverse is an unsynchronized, square cut gear, so if you try to engage it while moving at all, it grinds.
replacing the clutch and flywheel might fix it.
Whenever I hit Reverse, I'm always at a dead stop, with the brake mashed in... thats why ithe grinding troubles me.
Does anyone know if the TRD clutch is a worthwhile investment and replacement?
Should I go with OE Flywheel, or go the lightweight route?
Sorry bout all the Q's.... But I'm hopin to get some good A's!
trd clutch is overpriced for what it is. there are plenty of good choices for aftermarket clutches, just don't buy some ebay brand piece of crap.
depending on the condition, you can either buy a new oe flywheel, or have the one you got resurfaced. a light weight flywheel is a fun upgrade, but it can make moving away from a stop alittle harder because the car can stall easier.
Originally Posted by FlakoFigZ
thats explains alot thx. I figure my problem is the throwout bearing, cuz I press the clutch and I get a nice "SQUEeeeeeeAK" from under the car.
For starters get a grease gun and give it a good squeeze on the rubber covered nipple under you intake manifold. Ask a friend to push the clutch in you will find the place.
I don't know much about clutches but I know how to fix the squeak when pressing the pedal.
Looks like a rubber boot kind of like an accordion and 2 cylindrical metal things haha.
Its under the intake mani right behind the radiator.
Then see if you can actually hear the clutch once the squeezing sounds is out of the question
Try this... Start the car, make sure its in neutral with the hand brake up. Open the door, and sit on the floor outside of the car so you can stick your head under the dash, and push the clutch pedal with your hand. Can you easily hear the squeak? Is the noise coming from where the clutch pedal is attached to the firewall? If not get a friend to sit in the car, start it, keep it in neutral, hand brake up, and have him mess with the clutch pedal, try to pinpoint where the noise is coming from.
Re: Sounds like my clutch is falling a part! O_O
The reverse gear grind is normal as everyone has said. No synchro's and straight-cut gears will do that. That why you hear that loud whine when you move the car in reverse, its due to the gears. Thats your second problem fixed.
As for the clanking noise in your clutch the answer is: THROW-OUT BEARING, no doubt in my mind. It happened to me but i changed the clutch because i was going turbo and the problem was resolved.
From what i see you have your issues fixed with these quick tips. Now the clutch is going to be the most expensive part is you do decide to install something a bit more aggressive. If your car has I/H/E combo i would stick with the OEM clutch and just replace the bearing. On the other hand since they have to pull your transmission anyways, might as well do the switch to a better clutch. Its pretty much up to you and your wallet
Thanks guys.
And thanks Jsosa, haha I knew a fellow boricua would clear things up. Pa que tu lo sepa! jajaja
Once I have enough dough to fix things up I'll start the thread up again
JM Auto Racing
12-19-2014 06:36 PM
