TRD Turbo xB specs
TRD Turbo xB specs
Anybody seen this page yet: http://www.trdparts.jp/parts_trdturbo-complete.html
According to google:
The price on the page is ~2100 USD,
The max horsepower is ~148 @ 6400 RPM
The max torque is ~145 lb ft.
The package includes:
turbocharger (ball bearing turbine)
cooling duct
engine computer (E.C.U.)
intercooler & piping
oil cooler
TRD Sports emblem (front)
TRD Turbo emblem (rear)
TRD suspension
TRD muffler
TRD sport air filter
TRD brake pad (front)
http://www.trdparts.jp/movie/TRDturbo_bB.avi
Is there any chance of this getting imported if Toyota never comes through with a US version?
cooling duct
oil cooler
TRD suspension
TRD muffler
I went through the whole TRD Japan website just to see what kinds of goodies they have over there, and I'd have to say that the turbo is the one bit I'd most like to see over here.
That, and the ($1337!) HID headlight kit: http://www.trdparts.jp/parts_hid-h4.html
The list of english TRD Japan stuff:
http://www.trdparts.jp/english/list_bb.html
The (longer) list in Japanese:
http://www.trdparts.jp/list_bb.html
Team No Limitz
First off, the fuel management systems are way too complex...someone really needs to come out w/ something real soon to fix this problem. Second, most people dont have the resources to get a custom manifold fabbed up, and third, a lot of people have no clue whatsoever on how to custom build a CORRECT intercooling system for the turbo kit....its not just go out and buy an ebay intercooler and start fabbing up pipes. End cap designs, internal volume/flow, core sizing, core thicnkess etc have a lot to do w/ choosing the right setup...its not as easy as everyone thinks it is to just piece together a turbo kit or every manufacturer would be making them for these cars.
Originally Posted by Simplyscion
I doubt the ECU is gonna just swap right into our cars...theres probly gonna be a lot of modification to be done for this to work
Can you go into any more technical detail why the ECU swap wouldn't "just work"? I'd always assumed that the ECU's weren't really region locked, and on a car as simple as the xB (and Bb) I don't see any major differences that would cause issues. As far as I know, both cars have traction control, VSC, the same transmissions, and the same engines\sensors\etc. Other than settings dealing with emissions, it seems like it would be almost the same.
That said, this is my first real 'import' car (other than a 1991 Sentra SE-R w/a SR20DE), so I could be completely off.
In simple terms, the US ECU is closed loop and cannot be "over-ridden" so to speak. Any attempt to try and re-map some of the curves, it will reset itself.
I have a friend that works for TRD, has given me the TRD Japan catalogs and flyers, and when asked if it will be brought in the answer was, "Honestly, if TRD had plans to bring it here, they would have done it already."
Say No, the TRD kit will not work on US xBs.
But some peeps have turbo kits here in the US made from other sources. A few on the east coast have been successful so far.
Team No Limitz
Not good w/ electronics but main concern would be your emissions, then second I would believe you could possibly splice the 2 harnesses from the JDM and USDM boxes to work w/ the JDM ecu's...I think they are completely different from eachother resulting in causeing yourself a complete nightmare(I think)...have you ever seen our wiring harnesses out of the car?? Its like a 4" thick 11' long snake of a lot of wires and sensor plugs...I never have done a motor swap, nor will I want to do one after seeing all that wiring
I have been studying the book "How to Tune and Modify Engine Management Systems" by Jeff Hartman. Great book if your interested in this stuff, but by no means do I have any credibility w/ engine management yet
All I know is it probly wouldnt be worth all the time and effort, you would probably be better off ripping it all out and going w/ a standalone ECU.
Disclaimer: I could be completely wrong so take it for what it is
Any ECU guru's feel free to chime in and help out
I just wonder why they would go to the trouble of making a completely different harness for the xB vs the Bb. If they were trying to bring it over here at the lowest possible cost (hence the no factory cruise control, etc) why waste the time/effort making a completely different ECU for US-bound xB's? Why not just re-program a Japanese ECU with US settings, set it into closed-loop (read-only) mode, and be done with it?
The TRD ECU is probably exactly the same as the original with a few resistors or jumpers in different places to make it programmable with a SST. Just a guess though, I've never seen a real Bb, nor any of the Japan-only stuff in real life.
Well, the most basic reasons why you can't use a JDM ECU is that JDM engine are MAP sensored and USDM engines use AFM's. Also JDM engines do not have EGR valves, which USDM engines do. That's a relatively minor issue, but the MAP vs AFM is a bigger issue. Different harness and different ECU.
More than likely you can use the TRD Japan turbo if you switch your engine over to map and get the proper harness. The 86 guys do it all the time so we can run ITBs.
Oh yeah, also keep in mind that JDM gas is also higher octane than US premium, so they can advance their timing more aggressively. I don't remember the exact #, but it's either 95 or 97...I tend to think it's 97 AND it's low sulphur, but that's more an emissions thing.
the ECU shouldn't be too much of a worry. just have it reflashed by a GOOD tuner like technosquare for instance. none of the piggyback B/S. reflash all your stock maps to accomodate for boost duties. nothing better then a self-learning STOCK ecu.
http://www.technosquareinc.com <---- Tadashi is a tuning genius
that is if you don't mind shelling out the money for the turbo kit, THEN sending it in to get it reflashed.
I am going to talk to AEM at SEMA and possibly try to do something with their EMS for the xB. I know that only one person isnt going to sway their decision to offer a plug and play, but maybe if I can get their universal unit to work, we can get it in the works...
