turbo return line???
Old 05-30-2005, 02:41 AM
lastlookcustoms's Avatar
Default turbo return line???
I am like 99% sure this will work, but just need someone else to tell me that I am correct. I have the Greddy oil filter adapter on the car in between my filter and housing for my oil pressure gauge. The block has two ports on it. I can just run my oil return from my turbo into the adapter block cant I?
lastlookcustoms is offline
Old 05-30-2005, 04:50 AM
squirrel's Avatar
Hmm, sounds like it would work. As long as its sucking pressure back into the pan, and not out, resulting in blowing the oil back up into the turbo.
Most I know just put a fitting into the side of the oil pan.
I'll call and check for you.
squirrel is offline
Old 06-03-2005, 02:05 AM
Squirrel, thanks for the call. Sorry I didnt make it to the phone. Stuck in the shop trying to get this STI finished. When I really thought about it, you are right, it will just push the oil back up into the turbo. I am just going to tap a hole in the pan and be done with it.
Old 06-03-2005, 09:19 PM
squirrel's Avatar
Cool Stuart!
squirrel is offline
Old 06-03-2005, 09:42 PM
hotbox05's Avatar
where do you guys run the inlet for the turbo? where do you tap the oil for that ?
hotbox05 is offline
Old 06-03-2005, 11:11 PM
Ed
Ed's Avatar
Default Re: turbo return line???
Let me get this straight,you want to plumb a turbo's drain line to one of these?
Then the answer is NO. If you're talking about using the block adapter for your turbo's feed line,that answer is a YES
Turbo drain lines are just that,drains. You need to plumb it to run downwards and into the oilpan. Keep bends to a minimum and run as large a diameter line as possible.
Ed is offline
Old 06-04-2005, 02:35 AM
yea, I realized all this after I put the post up when I thought about it for more than a second. I am going to run my feed off of that like you said, but run my return to a tapped plug in the pan...
Old 06-10-2005, 09:41 PM
matchbox's Avatar
Default PE300
Once again taken care of by the Power Enterprise PE300. It comes with a new tapped oil pan for the oil feed return.
matchbox is offline
Old 06-10-2005, 11:28 PM
Default Re: PE300
I know... I bought a pan and was going to drill and tap it, but the way the pan is shaped, you cant really do it for the turbo. The line would have to go into the rear of the pan and its sloped weird. I dont want to run the return all the way into the front. I am just going to drill and tap the aluminum pan...
Boostedyota
12
02-20-2024 10:46 AM
Brammi
11-13-2016 03:46 AM
my06tc
06-25-2015 12:18 AM
Dbonehead6
05-28-2015 12:15 AM
nazblue5807
04-11-2015 12:20 AM
Quick Reply: turbo return line???
