What tranny fluid?
I'm getting ready to replace the tranny fluid in my xA and was wondering a couple things... I know that a lot of newer cars use ATF for their manual transaxles. I read somewhere that using a performance fluid would greatly improve the quality of my shifts. Should I go witha synthetic ATF from Royal Purple/Redline or use a higher viscosity synthetic gear oil? What weight would be the best? Would it be a negative to use a racing/hi-performance fluid? Thanks.
Redline MT-90 :bow:
....If you can find MT-90....
Well said, Redline MT-90.
Easy to change and will feel like a new car transmission. I will replace my tranny fluid every 30-40,000 miles. No side effects or any problems of any kind. Two quarts of MT-90 is what you need to fill tranny to the top (just below the fill hole). This is more fun than an oil change. I had to order 2 quarts from autozone. |
Red Line. Dyno tests showed about a 5hp increase in WHP on a 5.0 Mustang when oil, tranny lube and rear end lube were switched to Red Line. This was not in a Red Line ad.
I just put Red Line in my 06 xb at 1000 miles. |
