xA Air Conditioner won't turn off..
I have an 05 xA. When I turn on the air but not the A/C button, I still get ice cold air, indicating the compressor clutch is engaged. It's a pain when I just want fresh air,
but I'm wondering if the clutch is engaged when I am running the heater as well. The light on the A/C button does turn on & off. Thanks for any comments... |
Make sure you don't have it on defrost!
By defrost, do you mean where the air is being blown out (ie. under the windshield for defrost)? I have the air blowing straight out the grills toward the driver/ passenger...
even if the AC button is turned off, you have to adjust the air temperature...
(Post 3666352)
Originally Posted by DenverXA
(Post 3666348)
Yeah that's what I mean . . . so if you just have it blowing from the front vents and not the top vents on the windshield then I would guess you have a stuck compressor clutch or a blown relay or transistor that turns the clutch on. There should be a wire that powers the clutch which you could disconnect. The real test is if it puts out really cold air with the fan turned off while you are moving. If the clutch is stuck on all the times then you will burn out the compressor pretty quick since it normally is not on all the time . . . watch the high rpms of the engine or you could really do some damage to the compressor until you get it checked. Remember that it is running on the same belt as the water pump and aternator so if the compressor locks up you are going to loose the belt and engine cooling. |
Originally Posted by Jan06xB
(Post 3666377)
I've been driving all summer w/ the fan on defrost. What threw me a curve is that the front vents are still blowing at this setting (along w/ the windshield vents). Also, I didn't know that the A/C would turn on in defrost mode. I turned the fan to front vents, A/C button off & had only outside air (temp) blow in. Seems like all is well (?), I just didn't know the Scion system (1st year w/ the car). I've owned a lot of Toyotas... Thanks for your help & please respond if something doesn't seem right w/ my conclusion! |
YUP the vents on the side are for the side windows and the front vents center will also put out some air if you don't crank the dial all the way over as will the floor vents when on defrost. Glad we got that little problem figured out - they do that to dry out the air and clear the fog on the inside of the windshield - it clears in a few seconds on a rainy or cold day.
I think in the manual it shows you that when you put that knob to defrost as stated it will turn the ac on.So as he stated put it to anything but that ans see what happens.,then turn it to to def and see if it kicks in or if the rpms change.
Jan,
Thanks for your help. I see your URL is GasSavers.org. Should I be happy w/ the 31 mpg, mostly city, I'm getting w/ my xA? Ralph |
^ 31 seems to be about right for an xA. Glad you figured out the defroster issue.
(Post 3668192)
Jan,
Thanks for your help. I see your URL is GasSavers.org. Should I be happy w/ the 31 mpg, mostly city, I'm getting w/ my XA? Ralph |
Air Conditioner Won't Turn Off
Hi,
I have a 2004 Scion xB. The A/C is always on when the blower is on. (The A/C outlet is very cold) Even when I turn off the A/C switch. I did check to make sure it was not on defrost. Do you think this is a switch/relay problem? I know the compressor does not have an A/C compressor clutch relay - I've read it has a magnetic clutch? I've scoured the web and the manual but nothing about A/C stuck on. Thank you! Danny |
What happens when you mess with the temperature...if it stays cold I would imagine there's an issue with the blend door. If you have the manual there is a section on troubleshooting, so did that give you any ideas as to where to start troubleshooting?
You could also yank the A/C fuse(s) and see what happens. |
The Temp dial does affect (gets warmer...)I opened up the glovebox and saw the vent doors properly at work.
Today I disconnected the wired connection at the compressor AND I disconnected the plug at the high pressure sensor. Still blowing cold! I'm really bamboozled. Evidently the circuit is not so simple as the compressor operation directly dependent on the high pressure sensor connection (?) |
Did you get the wiring diagrams with your manuals? I hate chasing wiring issues but have found it's always much easier when you have some good references from which to work.
Only other thing I can think of is the compressor clutch is stuck/seized on... |
I'm clueless with wiring diagrams. I'm looking for a mechanic...
