AEM f/ic MAF voltage for XB?
Anyone out there running the AEM F/IC on a first gen xb?
If so, is it stock or boosted/sc? If it's stock would you mind doing two WOT runs for me and posting what the MAP voltage is? If it's boosted and you already know the answer, could you let me know? I already had the FI things on the car before getting the F/IC and now I can't check what to clamp the voltage at. Any help is appreciated. Thanks!! |
Re: AEM f/ic MAF voltage for XB?
If so, is it stock or boosted/sc? If it's stock would you mind doing two WOT runs for me and posting what the MAP voltage is? If it's boosted and you already know the answer, could you let me know? I already had the FI things on the car before getting the F/IC and now I can't check what to clamp the voltage at. Any help is appreciated. Thanks!! On a stock motor, the MAF voltage goes from 0.4 closed to 2.2v WOT... I hope that helps. |
Yes, it helps and is greatly appreciated. I would have started from 3v and worked my way up. Thought it would have been a lot higher. But this gives me a great foundation to work from. I appreciate it!
