The Fastest is here...
1 Attachment(s)
1 Attachment(s)
And heres the list:
Fully Built Race motor: Darton Sleved block Crower rods Arias Pistons Ferara Valves + 1 mm oversized Ferara retainers, Lockers, springs 3 way valve job Ported and polished head Schneider cams Weapon-R sheet metal intake Obx throttle body spacer Tial / Garrett Turbo Greddy Intercooler Greddy type R BOV CFT custom Exhaust manifold/ down pipe Stand Alone ECU: Microtech LT10 w/ Microtech Ignition and Bosch coil packs Electromotive crank trigger MSD wires / NGK plugs Fuel System: Walboro 255l , Aeromotive regulator , Perrin fuel rail , Aerospace Components custom fuel block for NX kit 680cc precision injectors Snow performance methanol injection DEI complete Cryo system Nitrous Express 100 shot kit tps activated. auto bottle opener w/ fire and ice cooling system for constant 1000 psi Aerospace Components 13" full floater disc brake system front and rear N.B.S 2.5" custom stainless exhaust w/ Aeroturbine Resonator and Skunk2 Can Oil system: Perma cool Perrin under drive pully Level 10 5 speed transmission Ferdenza clutch and fly wheel Autometer gauges 12 point roll cage JIC Majic dampner kit Axels: Gator Sparco seats, pedals and shift knob TRD short shifter Samco hoses Axis 18" Reverbs Nitto rubber VIS carbon fiber hood and hatch Greddy boost controller and timmer Attachment 108797 |
1 Attachment(s)
1 Attachment(s)
:shock:
WOW! Very nice xB! |
1 Attachment(s)
1 Attachment(s)
1 Attachment(s)
jajajja very nice xb man congrats
nice build. Can you post more on your turbo specs? Title says "fastest" you ran faster than a 12.8 in the 1/4? That's awesome if you did.
I noticed the head bolts are tiny on our motors, did you upgrade? Im worried that may be a weak link for high horsepower numbers. |
1 Attachment(s)
1 Attachment(s)
OK, here are some turbo specs: It's a Tial / Garrett Turbo 739548-5102TV
Ind wheel dia. 47.2mm Exd Whl Dia. 60.0mm Trim 62 A/R 0.60 That is compressor side. Here is Turbine side: 53.8mm 76 Trim A/R 0.64 Attachment 108782 |
wow i love it videos?
where did you run your coil packs to/at?
Nice... But way too much comfy stuff (Sound system, carpet, interior etc...) I'll still PWN you in the corners!:P
1 Attachment(s)
Coil packs....... They are on the right side of the motor between the the block and the battery tray. I have nothing stock under the hood so I made lots of room for things to fit.
Attachment 108781 |
man you have deep pockets must be nice
2 Attachment(s)
bB384 I don't need to worry about the corners, I'll be 10 car links ahead of you before we hit one. While i'm watching a Movie in surround sound.
for my coil pack friend heres a pic of the packs: Attachment 108778 Heres the ECU: Attachment 108779 |
The Tial ss V-band housing is nice. Good stuff. Good to see monster builds with the 1nz-fe.
Im sure to cure our thirst for curiousity a dyno sheet or even a timeslip/video of a 1/4 mile pass would be freaking awesome. Im guessing a 112mph trap is possible with those numbers. |
1 Attachment(s)
Now heres the real trick. SEE if you can figure this one out..... Ok i'll tell you. Crank trigger hooked to a perrin pulley. I can do what ever kind of timing necessary to make more boost. Timing exciter ring is by Electomotive. Car tuned by Rolo @ CFT.
Attachment 108777 |
