alarm diagrams
alarm diagrams
Hey guys,
Can someone please tell me the color wires and where you found them that are needed for the alarm P/L, P/W, parking lights, main door trigger, ign wires, starter wire, tach wire and anything else that may be related....if you dont want to post the wires you can send it to my email racingtoys@yahoo.com ....gotta install an alarm for my parents xB..hahah...good training for if i do buy one.
THANKS GUYS,
Chad
THANKS GUYS,
Chad
coasterlvr just posted this in the other thread:
Tach wire is black at the obd connector.
Here are some wires you can get at the keyless module:
Pin1 Headlights Red
Pin3 Hazard lights green/orange
Pin5 Rear Hatch Pop Brown/yellow
Pin6 Door Lock Brown/Yellow
Pin7 Door Unlock Green/ Black
Pin8 Door Lock Blue/White
Pin9 Priority Unlock Yellow/Black
Pin10 Door Unlock Blue/Red
Pin11 Horn
Pin 21 Passenger Door Trigger
i don't know about the starter, but i'm sure you can get to those from the internal fuse block, which is has the starter fuse labeled.
Pin1 Headlights Red
Pin11 Horn
I got one
Originally Posted by DenZinz
If anyone has a remote site, i can send them a .PDF and you can add a link on the forum to it.
12volts white/blue and white/red + ignition harness
Starter black + ignition harness
Ignition black + ignition harness
Door Trigger red/white - top of fuse box, 9 pin plug
Horn Trigger white/red - steering column
some other stuff here too
After searching and searching i found this from a good source.
Hope this helps
Scion XB
| 12V|wht/blu and wht/red |+ |ignition harness |
| STARTER|black |+ |ignition harness |
| IGNITION|black |+ |ignition harness |
| SECOND IGNITION|black/yellow |+ |ignition harness |
| ACCESSORY|blue/red |+ |ignition harness |
| POWER LOCK|blue/white *1 |- |driver kick, 14 pin plug |
| POWER UNLOCK|yellow/black *1 |- |driver kick, 14 pin plug |
| LOCK MOTOR|blue/orange |5wi|driver kick, 9 pin plug |
| UNLOCK MOTOR|yellow/green |5wi|driver kick, 9 pin plug |
| DISARM DEFEAT|blue/black |5wi|passenger kick, 9 pin plug |
| PARKING LIGHTS +|green | |headlight switch *2 |
| HEADLIGHTS|black/white |- |headlight switch |
| DOOR TRIGGER|red/white |- |top of fuse box, 9 pin plug |
| DOME SUPERVISION|use door trigger | | |
| TRUNK/HATCH PIN|common with doors | | |
| TACHOMETER|black | |data link connector *3 |
| SPEED SENSE|purple/white | |back of fuse box,18 pin plug|
| BRAKE WIRE|green/red |+ |brake pedal switch *2 |
| HORN TRIGGER|white/red |- |steering column |
| WIPERS|gry (L), blk/red (H)|+ |steering column |
| LF WINDOW UP/DN|red/blu - grn/wht |A |driver window switch in door|
| RF WINDOW UP/DN|red/blu - grn/wht |A |driver kick, 9 pin plug |
| LR WINDOW UP/DN|red/yel - grn/yel |A |driver kick, 4 pin plug |
| RR WINDOW UP/DN|red/blk - grn/blk |A |driver kick, 4 pin plug |
| RADIO 12V|blue/yellow |+ |radio harness |
| RADIO GROUND|white/black |- |radio harness |
| RADIO SWITCH|gray |+ |radio harness |
| RADIO ILLUMINATE|green |+ |radio harness |
| POWER ANTENNA|black/red |+ |radio harness |
| LF SPEAKER|pink - purple |+,-|radio harness |
| RF SPEAKER|lt. green - blue |+,-|radio harness |
| LR SPEAKER|black - yellow |+,-|radio harness |
| RR SPEAKER|red - white |+,-|radio harness |
NOTES:
*1 Meter these wires while turning the key in the driver door key cylinder. Unlock requires a double pulse. Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is blue/red (-) in the passenger kick in a 14 pin plug.
*2 Also found at the top of the fuse box in a 13 pin plug.
*3 The data link connector is below the fuse box. The tach wire is in pin 9.
Hope this helps
Scion XB
NOTES:
user9430961
09-15-2015 03:16 AM
Armystrong
08-31-2015 08:19 PM
