DIY: Mounting cold cathodes to the Oh Sh*t handles...56k no
Originally Posted by D_M_A_N
SAVE YOUR CA$H by going to www.oznium.com and get their cathode kits. You can get a rocker switch from the hardware store
Ozniums 12" cathodes are $6.49 a pair!
If you are doing grab handles, LED's are the way to go IMO
I'm talking about the flexible LED strips that oznium sells.
You can probably get by with two 9.5" strips, then cut them down to fit in all you grab handles.
Cathodes will be visible, you can tuck the LED's in the handles if you take out a rib.
you'll have to do some soldering. The strips show you where you can cut them. And it also has a little pad or something to solder to. But it might be worth it to just spend a little more and get the shorter ones that fit
The lights are generally wired in the strip in series or three and then a little resistor. You have to watch where you cut to complete the series to keep all the bulbs lit.
I noticed that the wiring pins locations, for the + and- on the strip changed in the second half. If I didn't make sure what is the + feed and - feed was on the second half, and just went by the locations, I would have hooked it up wrong
I used a dremel to grind away the silicone at each of the two pins locations , Checked with a meter to make sure, and then soldered the wires to the both + and - filled with silicone and let dry overnight.
I would say if you are the type of person that has a hand full of thumbs, best buy the correct size strips as the pin locations are pretty small.
Originally Posted by kloud09
im installing the cold cathodes to the osh on my box and i was wondering what size fuse should i use so i dont fry the converters?
thanx 4 the info CanxB.
aaahhh vancouver eh. i grew up in in one of the small border towns in WA. my friends and i used to go to Van all the time. i sure miss being able to go there whenever i please.
Originally Posted by enjoi
Hey i was wondering how you put 2 cold cathodes kit under one switch?
https://www.scionlife.com/forums/viewtopic.php?t=29238
It has a diagram and everything
randode
44
Jun 29, 2004 04:19 PM
Besk_one
Nov 17, 2003 09:28 PM
